simplextech Posted March 13, 2019 Share Posted March 13, 2019 This thread will be updated as development progresses. Feedback is needed for continued development ALPHA: Polyglot Hubitat Elevation NodeServer Github: https://github.com/simplextech/udi-hubitat-poly This nodeserver provides device integration from the Hubitat hub to your ISY via Polyglot. Current development just started umm (yesterday? 03/12/19) so please be patient. The initial code has been pushed to github and is available for all to use and contribute to. Currently supported/tested devices: Hubitat Virtual Switch Zooz ZEN15 Power Plug Zooz/Dome ZSE09 Motion Sensor Zooz ZSE40 4-in-1 Sensor Fibaro ZW5 Multi-Sensor NYCE Motion Sensors - ZigBee Device support roadmap: All supported devices from Hubitat Hubitat supported device list: https://docs.hubitat.com/index.php?title=List_of_Supported_Devices Hubitat device support from built in apps Philips Hue Lutron Caseta Pro/RadioRA/Select Known Issues: Device status on start is not always correct until the device updates. I need to implement a query on startup. Query function for all devices not implemented yet Hub Management functions are not yet implemented (status/reboot) dependent on availability This integration presents the devices from Hubitat to Polyglot via the Maker API Hubitat App. This app allows devices to be queried and controlled via the REST interface. The current implementation uses a combination of the REST interface for discovery of devices and a websocket connection for real-time status/updates of the devices. The devices are then presented within the ISY for control/status use from the Admin Console or from programs. Please make device requests either via this post or via a request on the Github page. If I have the device I can add support as time allows. If I don't have the device then donations of devices or funds for devices to test with are always welcome! Some funding may go towards beverages Hubitat Elevation information https://hubitat.com/ https://community.hubitat.com/ Eye Candy: Link to comment Share on other sites More sharing options...
simplextech Posted March 14, 2019 Author Share Posted March 14, 2019 Update: First trial of Lutron Caseta Pro integration is done. Pico remotes are integrated (5 button remote) with button presses seen by ISY Link to comment Share on other sites More sharing options...
snowtech Posted March 14, 2019 Share Posted March 14, 2019 EDIT: So sorry, i just noticed this message came to this thread... i dont know why by disregard... Im still stuck with adding ST to ISY... I put ISY in learn mode and put ST to search for it and doesnt find it Link to comment Share on other sites More sharing options...
simplextech Posted March 14, 2019 Author Share Posted March 14, 2019 @snowtech I think a different thread would be appropriate as Hubitat is not ST and this NodeServer does not work with ST. However I'm happy to run a test with an ISY and ST integration. Link to comment Share on other sites More sharing options...
mjohnson007 Posted March 14, 2019 Share Posted March 14, 2019 Hi simplextech was reading the tread over at HE about you polygot work sounds very promissing, but I was wondering what it would take to reverse it and have HE control ISY, as I love the setup in ISY with scenes, control over insteon ramp rates on levels writen to the devices, yet I love the simplicity that HE has on it rules engine, lock manager, control of other things like zigbee, sonos, ecobee, and well pretty much everything except Insteon , I also like where sharpTools is going with there UI addon for HE as I want to build som wall con trolers, as i have tried the Insteon bridge that cwwilson08 has worked on and while it works it does require a 2245 hub and a RaspPi running the hombridge stuff, where i think having the ability to control and get status from ISY by/thru HE would be great as it would bring the best of both world into one. Don't get me wrong I have been a fan of ISY for many years and have a home with 50+ insteon devices/sonos/ecobee/zigbee locks etc, and was a programmer many years ago, but as i get older, I like things simpiler and graphical rules/smart lighting which HE provides make it easier for me to envision stuff. Is this something you may one day look at or be persuaded to attempt? thnx M Link to comment Share on other sites More sharing options...
simplextech Posted March 14, 2019 Author Share Posted March 14, 2019 41 minutes ago, mjohnson007 said: Hi simplextech was reading the tread over at HE about you polygot work sounds very promissing, but I was wondering what it would take to reverse it and have HE control ISY, as I love the setup in ISY with scenes, control over insteon ramp rates on levels writen to the devices, yet I love the simplicity that HE has on it rules engine, lock manager, control of other things like zigbee, sonos, ecobee, and well pretty much everything except Insteon , I also like where sharpTools is going with there UI addon for HE as I want to build som wall con trolers, as i have tried the Insteon bridge that cwwilson08 has worked on and while it works it does require a 2245 hub and a RaspPi running the hombridge stuff, where i think having the ability to control and get status from ISY by/thru HE would be great as it would bring the best of both world into one. Don't get me wrong I have been a fan of ISY for many years and have a home with 50+ insteon devices/sonos/ecobee/zigbee locks etc, and was a programmer many years ago, but as i get older, I like things simpiler and graphical rules/smart lighting which HE provides make it easier for me to envision stuff. Is this something you may one day look at or be persuaded to attempt? thnx M I've seen this request on the Hubitat community as well. The current priorities are in prototyping this with ISY with hopeful full integration achievement. Next inline will be a HomeSeer plugin for integration with Hubitat. I am giving thoughts to the ISY -> Hubitat integration as it should also be workable. The limitations of the Hubitat development environment may pose to be a challenge but is still unknown at this time. Link to comment Share on other sites More sharing options...
simplextech Posted March 15, 2019 Author Share Posted March 15, 2019 The Hubitat integration will bring two things currently not available with ISY today and possibly other things as well. Of those are namely Lutron Caseta Pro / RadioRA integration (could later be done as stand alone nodeserver. I may look into this if nobody else does) ZigBee ZHA device support What ZigBee devices if any are of particular interest to people? Link to comment Share on other sites More sharing options...
mjohnson007 Posted March 29, 2019 Share Posted March 29, 2019 Yale Assure Lock Touchscreen Zigbee, as I know I could replace all the modules @$60 a pop with Zwave but with 6 locks thats alot of money, unless there is a better way then Hubitat to ISY Link to comment Share on other sites More sharing options...
simplextech Posted March 29, 2019 Author Share Posted March 29, 2019 9 minutes ago, mjohnson007 said: Yale Assure Lock Touchscreen Zigbee, as I know I could replace all the modules @$60 a pop with Zwave but with 6 locks thats alot of money, unless there is a better way then Hubitat to ISY That's a lot of locks! That's why I don't have any smart locks as I would need too many! Options are: (Understanding this nodeserver is alpha and was not intended for nodeserver store release just yet) get a hub and setup the lock in the hub and then send me the device data to add support to the nodeserver get a hub add support yourself find someone else with a hub + lock to provide the device data needed to add support send me a lock to test with and add support Link to comment Share on other sites More sharing options...
Adolfo Posted April 9, 2019 Share Posted April 9, 2019 On 3/14/2019 at 10:14 PM, simplextech said: The Hubitat integration will bring two things currently not available with ISY today and possibly other things as well. Of those are namely Lutron Caseta Pro / RadioRA integration (could later be done as stand alone nodeserver. I may look into this if nobody else does) ZigBee ZHA device support What ZigBee devices if any are of particular interest to people? Definitively HUE. They are adding products every day, the quality is exceptional. Whats needed is a very solid and reliable handle of HUE devices and sensors and interaction with ISY. Link to comment Share on other sites More sharing options...
simplextech Posted April 11, 2019 Author Share Posted April 11, 2019 On 4/9/2019 at 4:18 PM, Adolfo said: Definitively HUE. They are adding products every day, the quality is exceptional. Whats needed is a very solid and reliable handle of HUE devices and sensors and interaction with ISY. Hue lighting is ZLL (Zigbee Light Link) and works best with the Hue bridge. There is a nodeserver for that. However the lights can also be paired directly as Zigbee ZHA devices but some of the features and firmware update capabilities are lost. The Hue accessories (motion, switches) are Zigbee ZHA devices are according to Hubitat are compatible/supported. If it is supported by Hubitat it can work with this nodeserver with adjustments of being added as a nodetype which is a rather simple process. Link to comment Share on other sites More sharing options...
Adolfo Posted April 17, 2019 Share Posted April 17, 2019 SImple question...where on hubitat web-control do I find My LOCAL Maker API URL of Full Device Details. All other steps to add polyglot node are done. Thanks Link to comment Share on other sites More sharing options...
simplextech Posted April 17, 2019 Author Share Posted April 17, 2019 I'll see about putting together a screen-shot walk through but the steps are Starting from main/home page: Apps -> Top right - Add Built-in App Select Maker API from the list Ensure Allow Access via Local IP Address Click Done In the Apps List click Maker API Verify your local setup Click the box for "Allow Endpoint to Control These Devices" - Select your devices you want to control from ISY Scroll down and you'll see "Endpoints" and and Links for the URL's: You want the "Get All Devices with Full Details" url Link to comment Share on other sites More sharing options...
Adolfo Posted April 18, 2019 Share Posted April 18, 2019 OK, Now i do have "Hubitat" on my Isy "Main" device list, but there is not more than that. No Hue Bridge or light device. What I am missing? Thanks again. Link to comment Share on other sites More sharing options...
Adolfo Posted April 18, 2019 Share Posted April 18, 2019 Here I have another question. I have added 5 Groups and 25 Hue Devices, but the Hue sensor is not listed. Where can I find it to add it? Thank You Link to comment Share on other sites More sharing options...
simplextech Posted April 18, 2019 Author Share Posted April 18, 2019 6 hours ago, Adolfo said: Here I have another question. I have added 5 Groups and 25 Hue Devices, but the Hue sensor is not listed. Where can I find it to add it? Thank You I'm not sure I understand what/where you added things to.... When you add a device to Hubitat if it's one of the supported devices (which is not everything but is growing) then you MUST ALSO go to the Maker API app and select those devices to be presented through Maker API. Once that is done you will then have to restart the nodeserver to re-read the Hubitat information. Any supported devices should automatically create new node entries in the ISY Admin Console for those devices. BTW - Hue bridge/lights are supported via Hubitat Hue app. Hue Sensors/Switches etc are NOT supported via the Hue bridge by Hubitat and must be paired directly to Hubitat NOT the Hue bridge for them to work with Hubitat. Link to comment Share on other sites More sharing options...
Adolfo Posted April 18, 2019 Share Posted April 18, 2019 Thank you for following up here. I have Hue app and Bridge working perfectly with about 25 devices and 5 groups + 2 sensors. I added the "Hue Bridge Integration" where you see Devices ( lights, not sensors as you said not working at this time ) and the Hue Bridge. Then I followed your steps and added Maker Api and copied the " Get All Devices with Full Details" url to the polyglot Node. Now, on ISY944 I just have "Hubitat" but no lights or groups. Advice, Adolfo Link to comment Share on other sites More sharing options...
simplextech Posted April 18, 2019 Author Share Posted April 18, 2019 57 minutes ago, Adolfo said: Thank you for following up here. I have Hue app and Bridge working perfectly with about 25 devices and 5 groups + 2 sensors. I added the "Hue Bridge Integration" where you see Devices ( lights, not sensors as you said not working at this time ) and the Hue Bridge. Then I followed your steps and added Maker Api and copied the " Get All Devices with Full Details" url to the polyglot Node. Now, on ISY944 I just have "Hubitat" but no lights or groups. Advice, Adolfo Sensors will never be supported via the Hue bridge integration. This is per Hubitat. Just an FYI. Did you go into Maker API and select the Hue Bridge and Lights that you want exposed to the nodeserver via Maker API? Here's a sample screenshot of a Maker API configuration page showing my test devices and Hue lights Link to comment Share on other sites More sharing options...
RRoyceus Posted April 22, 2019 Share Posted April 22, 2019 I am stuck at the same place. I see Hubitat in my ISY. I add a generic Zigbee bulb in Hubitat. I restarted my Rapberry Pi. In the Maker API, it is listed in the select devices, but I cannot see it in the ISY. Link to comment Share on other sites More sharing options...
Adolfo Posted April 22, 2019 Share Posted April 22, 2019 Now I feel better....Its not just me. Link to comment Share on other sites More sharing options...
simplextech Posted April 22, 2019 Author Share Posted April 22, 2019 11 hours ago, RRoyceus said: I am stuck at the same place. I see Hubitat in my ISY. I add a generic Zigbee bulb in Hubitat. I restarted my Rapberry Pi. In the Maker API, it is listed in the select devices, but I cannot see it in the ISY. Not all devices are supported. I don't have any generic Zigbee bulbs... so those are not tested added yet If you have devices you find that aren't working send me the output of your Maker API URL so the device types can be added. Or feel free to fork the code and add them and send a PR. Link to comment Share on other sites More sharing options...
RRoyceus Posted April 22, 2019 Share Posted April 22, 2019 See if the attached is what you need. all.pdf Link to comment Share on other sites More sharing options...
simplextech Posted April 22, 2019 Author Share Posted April 22, 2019 5 minutes ago, RRoyceus said: See if the attached is what you need. all.pdf 33.51 kB · 0 downloads That's what I need. I'll get that added. Link to comment Share on other sites More sharing options...
simplextech Posted April 22, 2019 Author Share Posted April 22, 2019 29 minutes ago, RRoyceus said: See if the attached is what you need. all.pdf 33.51 kB · 0 downloads Changes were made. Please update and provide information/feedback as I don't have any generic Zigbee bulbs. What bulb are you using BTW? Link to comment Share on other sites More sharing options...
RRoyceus Posted April 22, 2019 Share Posted April 22, 2019 3 hours ago, simplextech said: Changes were made. Please update and provide information/feedback as I don't have any generic Zigbee bulbs. What bulb are you using BTW? Thank you! That was quick. The bulb is a Sengled model E11-G13. I will let you know if I get it working. Link to comment Share on other sites More sharing options...
