3- Pin LampLinc into a 2 Pin Outlet???
Is it okay to plug in a 3-pin Lamplinc into a 2-pin electrical outlet using a 3- wire to a 2-wire adapter? Will this cause anything in the 3-pin LampLinc not to function?
Unless the newest LampLincs where redone. NO problem. All of mine [yes I peaked] the Green Ground wire goes from the rear male pins to the female output pin and does not even connect to the internal PCB board.
If you could connect the adapters ground wire to a grounded screw. Then anything on the LampLincs output that used a ground would have one.
