Network Module UDP Broadcasts
I apologize if this is written somewhere or should be obvious... does the network module allow the ISY to listen to UDP broadcasts from a given IP/port? I see in the specs for the module it specifies it can make UDP broadcasts, I just don't see anything specifically indicating it can listen and react as well.
I'm guessing the answer is yes, I just want to be sure...
Thanks!!
Chris
No,
The network module is only for sending, at least at this point. It doesn't even process the response.
If you have control over what is sent, you can control devices and programs using the rest HTML interface.
-Nick
