KeypadLinc 8-button shows up as 8 devices
I just added a new KeypadLinc 8 Button Dimmer 2334-2 v.45 to my ISY 944i/IR PRO v4.7.3. Normally, I would expect a keypad to register as a top-level device for A, the load, and then a level lower in the device tree would be B through H. When registering this keypad, I see 8 individual devices at the same level in the tree. (For example, I can place different buttons in different folders.) Is this an expected change, or something that could be resolved in the beta firmware? I tried to google this but couldn't find the right keyword to distinguish this from normal button grouping. Thanks.
Select the device, right click, you should see an option to "group" it.
Thanks! That was it. I don't remember having to do this step before.
