2843-222 installation
I have several 2843-222 window door sensors arriving this week and was wondering if anyone has a recommendation as to what double sided tape works the best.  I have not had a lot of luck with the supplied tape in the past.  Is there an option out there that seems to hold up over time and secondly is there a thin tape option?  If not, what are you using for mounting these sensors, mounting with screw not an option.
Tom
There are numerous options available from either Home Depot or hardware stores. The tapes are rated by the weight they can hold. The higher the rated weight capacity the better the adhesive.
Yes, there are also thin tape options available.
