New Portal User
Hello All,
New Portal user just purchase,  and preordered my Polisy Pro and i'm in need of a little understanding of how do I now login to my ISY 994ipro using my iPhone app remotely to turn lights On/Off.  I have the portal setup with my ISY,  Account Created, Verified, Module approved, and so on as per instructions.  what I don't understand is I have the app Ekeypad Pro but was never able to use for remote access because of port forwarding problems,  so my question is how?  what else do I need like setting up the ports in the app is it 443? HTTPS? which IP address do use? and login and pw,   sorry if this is stupid I just need to be pointed in the right direction this is the part I don't understand.
Thank You in Advance!
pmhgeneral.
In eKPro you the steps are as follows:
Config -> Automation Systems -> MyISY (whatever you named it) -> Configuration Details
Network Address = my.isy.io
Port Number = 443
ISY Username = Your portal login
ISY Password = Your portal password
simplextech,
A big Thank You Sir,  this is just what I needed I can now login remotely wasn't sure if it should have been saved as HTTPS or HTTP or if it matters? still not sure how the work around works with the portal and would be interesting to know. this way of login would it also work with other iPhone ISY apps or only if they are setup for the portal?
Again Thank You.
52 minutes ago, pmhgeneral said:
simplextech,
Again Thank You.
That information can be used by almost? anything to connect to your ISY through the Portal connection.  The ISY Portal acts as a proxy service to your ISY so anything that can make an secure (port 443) HTTP connection and authenticate should work.
Okay,  now I understand better,  but isn’t the port 443 for HTTPS or does that not matter at this point? And one other question should I now go into my modem and clean up (delete) the port forwarding I have that didn’t work for me to login remotely?
Again Thank You for your Help!
Yes port 443 is the default port for HTTPS.
YES definitely go into your router and clean up / remove the port forwarding rules.
