1wire install issue. OWFS: Directory doesnt exist
So close to getting this working (I think) but running into a snag...
I installed Pi using the install guide: http://automationshack.com/Files/Raspbian_Setup_V5.pdf  Just before installing Nodelink I followed the 1wire setup from this guide from sheepwalk for the RPI2v2 interface I bought. That all went fine I think as I can now type owdir which returns the proper result and owread XXXX/temperature returns the correct temp.
http://www.sheepwalkelectronics.co.uk/RPI2v2_software.php
The bummer it seems is inside NodeLink Im getting the following:
2019-07-15 18:01:50 - ISY NodeLink Server v0.9.33 started
2019-07-15 18:01:50 - OS: Linux raspberrypi 4.19.57-v7+ #1244 SMP Thu Jul 4 18:45:25 BST 2019 armv7l GNU/Linux
2019-07-15 18:01:50 - Mono version: 5.18.0.240 (Debian 5.18.0.240+dfsg-3 Sat Apr 20 05:16:08 UTC 2019)
2019-07-15 18:01:50 - Web config server started (http://192.168.1.101:8090)
2019-07-15 18:01:51 - ISY resolved to 192.168.1.125 (5.0.15A)
2019-07-15 18:01:51 - ISY Node Server config detected (profile 1)
2019-07-15 18:01:52 - OWFS: Directory does not exist [owfs1]
Any idea what I missed?
Thanks!!
Here's what I did to get OWFS running on a new Pi install:
Edit the modules file by the following command:
sudo nano /etc/modules
Add the following two lines to the file:
sudo modprobe i2c-bcm2708
sudo modprobe i2c-dev
Install the required new files:
sudo apt install i2c-tools owfs ow-shell
Edit the owfs.conf by the following command:
sudo nano /etc/owfs.conf
Comment out (by putting a # at the beginning) the line that says:
server: FAKE = DS18S20,DS2405
Then below it add the following line:
server: device=/dev/i2c-1
In owfs.conf Ensure the following changes are also present and not commented out:
mountpoint = /mnt/1wire
allow_other
Create the 1-wire directory:
sudo mkdir /mnt/1wire
Create service file by:
sudo nano /etc/systemd/system/owfs.service
Add the following lines to the file:
[Unit]
Description=1-wire filesystem FUSE mount
Documentation=man:owfs(1)
After=mysql.service
[Service]
Type=forking
ExecStart=/usr/bin/owfs -c /etc/owfs.conf
ExecStop=/usr/bin/umount /run/owfs
RuntimeDirectory=owfs
[Install]
WantedBy=multi-user.target
Enable and start the OWFS service
Thank you so much! It was the last 2 steps I needed to do.
Up and running, so awesome to have this working again!!
