Adding Variables to Mobilinc X do not show on ISY
How long do I have to wait for a variable to show on my ISY when I add it through mobilinc x.  Should I add it to ISY the hope it shows on Mobilinc X?
If you see the variable in MobiLinc X, it’s in your ISY. You have to close and reopen the Admin Console to see the newly added variable.
Wes
Wes
Thanks that worked.  So if I want to delete a variable should I delete from ISY or mobilic x?
You should use MobiLinc X as it’s a cleaner experience if you are on firmware 4.
After adding or deleting on firmware 4 via MobiLinc X you must close/reopen Admin Console.
Wes
