ISY Pre-Wire Question
Even though I can't get my ISY until December, I want to go ahead and get everyting ready to install it. I was planning to put a 3-gang box next to my electrical panel and feed it with a dedicated 220V breaker. I will put a 2406H phase coupler in the middle position with an outlet on each side, each wired to a different leg of the feed.
I plan to plug the PLM from the ISY-99.9 into one outlet and the PLM from an EZIO8 into the other outlet.
1- Any problems with this arrangement?
2- Where is the best place to plug in the ISY power supply? The PLM feed through outlet? An adjacent outlet on the same circuit as the PLM? A different circuit from the PLM?
Mike,
Your set up should work fine. I have my ISY power supply plugged into my PLM.
SteveL
