Power Supply for the ISY
My power supply for the ISY has failed today. The green light is dim on it and keeps turning on and off. The ISY is not getting any power.
I close on my house this week and everything has to be in working order so I need to replace it ASAP.
I borrowed a friends power supply for their ISY but it is different.
The one that I have which failed is unbranded and has a Model# HRS050050
Input 100-240V 50/60Hz
Output: 5V 500mA
The one he gave me says TP_Link Model# T090060-2B1
Output 9V .6A
I think he may have given me the wrong supply? Or can the ISY take a range of input voltage?
I'm also not sure of the tip polarity of the connection or the exact size of it. Anybody know where I can get a replacement?
Found the WIKI where it says "You can try any power supply that outputs anywhere between 5 volt and 30 volts,center positive, 2mm barrel connector"
