Run Out of Memory
zerop
Well, after a long time wondering what exactly the limitations of my ISY994i Pro actually is (even after posing the question here and no on really knowing) I've finally found it.
I made my 1,245th program, hit save and found it highlighted in yellow.  In the program Summary tab it stated "Not Loaded" and "Out of Memory".
Current system:
1,244 programs
371 Variables (342 integer, 29 state)
340 Network Resources
410 Custom Notifications
77 Devices (all Insteon with the exception of three Z-Wave)
1 hour ago, Techman said:
In the admin console under TOOLS | SYSTEM STATUS it will show the details of the ISY memory.
I'm fairly certain that is a different memory than what is used for loading the programs.
Current system:
1,244 programs
Thanks for the post.  I realize your system is different than mine but it gives me a feel for how much you can stuff in that little black box.
Current system:
1,244 programs
I must say you certainly have a lot going on.
Do a PLM link count. It also could be that you exceeded PLM memory.  The newer PLMs hold about 1000 links. The PLM link count will vary depending on ISY activity.
PLM Links = 468
Lots of variables and programs.  It would be interesting to know what all is going on if for nothing else but to give me some ideas I may not have thought of  :)
You've got plenty of available PLM link memory. What does the ISY memory show?
System memory?
Total: 1015MB
Reserved: 101MB
Used: 87MB
Bad: 0MB
Free: 826MB
But system memory is different than the memory used to load the programs.
Too much to tell you all the details but I've got a 2-zone HVAC system, 2 whole house fans, a garage fan, 2 hot water recirculation pumps, all the lights in the house, inside and outside cameras, door and window sensors and a dozen CAO wireless tag temperature sensors all integrated together along with blue iris for the cameras (used as motion sensors too) as well as being integrated into my and my wife's cell phones using Tasker and finally all of it used in conjunction with several Amazon Echo Dots around the house.
Sounds comprehensive I was just struck by the number of programs vs the small number of devices you listed.  Perhaps another thread of "interesting" programs would be more appropriate.
I do have a couple hundred program doing nothing but getting my two thermostat temperatures into variables.  This could be solved moving to v5.
Example of one of my series of programs that gets used quite often:
When the AC turns on and it's 3 degrees cooler outside than inside (checking temperature using the wireless tags), Alexa states it's cooler outside.  If the back door is opened within three minutes the AC is turned off and the house fans are turned on.
I should have guessed it was either HVAC or Weather related for the quantity :)
      377k
