ISY994 Sees Deleted Elk Areas
SOLVED -  have deleted all unused areas from my Elk M1 Gold security panel but my ISY with the Elk Module installed sees these deleted areas, which are in turn viewable in MobiLinc X.  MobiLinc support says that if the ISY sees these areas MobiLinc will too.  These areas were deleted long before I installed the Elk module so I'm not sure how the ISY ever saw them.  Anyone know how to fix this?
Solution - Recreated deleted areas 3-8 in RP2,  sent to Elk panel, deleted areas 3-8 and then sent all areas to Elk panel.  Refreshed topology in ISY.  Thanks to Michel for this solution.
Edited by RandyB
Issue Resolved
