Globe RGB Wifi Smart Bulbs ISY994 integration
I'm trying to have all my automation devices under one app, one controller, the isy994zw. Would like to control these Globe wifi bulbs (no insteon switches) and be able to turn on, off, change color.
I can do this with google assistant but want to be able to do this with the agave or mobilinc HD app. Is this possible without too much programming?
Thank-you
Did some more reading,
I believe i can use the ISY node server to configure wifi bulbs? just one at the moment. Its a Globe RGB wifi smart bulb (from costco). I just don't know where to begin. Is there a list of commands I program? is there a plugin i use? Can someone please point me in the right direction.
Thank-you
Thank-you
To my knowledge there is no NodeServer currently supporting "Globe Wifi Bulbs".  I looked at their website and they have no mention of any API information nor developer integration.  Suspicion is they are probably a Tuya backed device.  There currently is not a Tuya NodeServer either.  If you want to expand your home automation I would suggest Philips Hue or LiFX bulbs as they are already well supported.
Wifi devices in general are NOT automation friendly beyond the common Google/Amazon integrations that everyone supports.  There are some Wifi exceptions of course but if your plan is to integrate with the ISY I suggest you check device compatibility before purchase.
