Honeywell TH6320 Tstat can't set heat setpoint
Hi, I have a couple of Honeywell TH6320ZW2003 Zwave thermostats that have a bit of a kink.  They work well in my network and I have the ability to change their mode properly.  However, when I try to set the Heat setpoint (I'm not using the Cool functions so I don't know if that's the same), the thermostat always sets to 4.5C no matter what setting I attempt.  I can manually set the temp and it displays properly in the ISY.   I've tried excluding and re-including the device with no success. I'm running ISY v5.0.16A. Attached is device info:
Fri. 12/06/2019 03:19:15 p.m. : [ZW-SHOW         ] ----------------------------------------------
Fri. 12/06/2019 03:19:15 p.m. : [ZW-SHOW         ] Tstat - LR FP
Fri. 12/06/2019 03:19:15 p.m. : [ZW-SHOW         ] ZW085_1 uid=85 type=4.8.6 mid=57 tid=17 pid=8
Fri. 12/06/2019 03:19:15 p.m. : [ZW-SHOW         ] Association Group ID 1
Fri. 12/06/2019 03:19:15 p.m. : [ZW-SHOW         ]    -  x5E  V2   ZWAVEPLUS_INFO
Fri. 12/06/2019 03:19:15 p.m. : [ZW-SHOW         ]    -  x85  V2   ASSOCIATION
Fri. 12/06/2019 03:19:15 p.m. : [ZW-SHOW         ]    -  x86  V2   VERSION
Fri. 12/06/2019 03:19:15 p.m. : [ZW-SHOW         ]    -  x59  V1   ASSOCIATION_GROUP_INFO
Fri. 12/06/2019 03:19:15 p.m. : [ZW-SHOW         ]    -  x31  V5   SENSOR_MULTILEVEL
Fri. 12/06/2019 03:19:15 p.m. : [ZW-SHOW         ]    -  x80  V1   BATTERY
Fri. 12/06/2019 03:19:15 p.m. : [ZW-SHOW         ]    -  x81  V1   CLOCK
Fri. 12/06/2019 03:19:15 p.m. : [ZW-SHOW         ]    -  x70  V4   CONFIGURATION
Fri. 12/06/2019 03:19:15 p.m. : [ZW-SHOW         ]    -  x5A  V1   DEVICE_RESET_LOCALLY
Fri. 12/06/2019 03:19:15 p.m. : [ZW-SHOW         ]    -  x72  V2   MANUFACTURER_SPECIFIC
Fri. 12/06/2019 03:19:15 p.m. : [ZW-SHOW         ]    -  x71  V3   NOTIFICATION
Fri. 12/06/2019 03:19:15 p.m. : [ZW-SHOW         ]    -  x73  V1   POWERLEVEL
Fri. 12/06/2019 03:19:15 p.m. : [ZW-SHOW         ]    -  x9F  V1   SECURITY_2
Fri. 12/06/2019 03:19:15 p.m. : [ZW-SHOW         ]    -  x44  V3   THERMOSTAT_FAN_MODE
Fri. 12/06/2019 03:19:15 p.m. : [ZW-SHOW         ]    -  x45  V1   THERMOSTAT_FAN_STATE
Fri. 12/06/2019 03:19:15 p.m. : [ZW-SHOW         ]    -  x40  V3   THERMOSTAT_MODE
Fri. 12/06/2019 03:19:15 p.m. : [ZW-SHOW         ]    -  x42  V1   THERMOSTAT_OPERATING_STATE
Fri. 12/06/2019 03:19:15 p.m. : [ZW-SHOW         ]    -  x43  V2   THERMOSTAT_SETPOINT
Fri. 12/06/2019 03:19:15 p.m. : [ZW-SHOW         ]    -  x6C  V1   SUPERVISION
Fri. 12/06/2019 03:19:15 p.m. : [ZW-SHOW         ]    -  x55  V2   TRANSPORT_SERVICE
Fri. 12/06/2019 03:19:15 p.m. : [ZW-SHOW         ] - Secure
Fri. 12/06/2019 03:19:15 p.m. : [ZW-SHOW         ] Last working route from ISY to Node  85 - Tstat - LR FP
Fri. 12/06/2019 03:19:16 p.m. : [ZW-SHOW         ]    - Node  80 - Garage ZWave Repeater
Fri. 12/06/2019 03:19:16 p.m. : [ZW-SHOW         ]    - Node  14 - Tstat - Sharons Office
Fri. 12/06/2019 03:19:16 p.m. : [ZW-SHOW         ] Node  85 - Tstat - LR FP has the following neighbors
Fri. 12/06/2019 03:19:16 p.m. : [ZW-SHOW         ]    - Repeater - Node   8 - Tstat - Living Room
Fri. 12/06/2019 03:19:16 p.m. : [ZW-SHOW         ]    - Repeater - Node  10 - Tstat - Master Suite
Fri. 12/06/2019 03:19:16 p.m. : [ZW-SHOW         ]    - Repeater - Node  14 - Tstat - Sharons Office
Fri. 12/06/2019 03:19:16 p.m. : [ZW-SHOW         ]    - Repeater - Node  15 - Tstat - Media Room
Fri. 12/06/2019 03:19:16 p.m. : [ZW-SHOW         ]    - Repeater - Node  16 - Tstat - Foyer
Fri. 12/06/2019 03:19:16 p.m. : [ZW-SHOW         ]    - Repeater - Node  17 - Tstat - Gordons Office
Fri. 12/06/2019 03:19:16 p.m. : [ZW-SHOW         ]    - Repeater - Node  18 - Tstat - Laundry Room
Fri. 12/06/2019 03:19:16 p.m. : [ZW-SHOW         ]    - Repeater - Node  19 - Tstat - Powder Room
Fri. 12/06/2019 03:19:16 p.m. : [ZW-SHOW         ]    -          - Node  67 - Lock - Front Door
Fri. 12/06/2019 03:19:16 p.m. : [ZW-SHOW         ]    - Repeater - Node  71 - Hallway ZWave Repeater
Fri. 12/06/2019 03:19:16 p.m. : [ZW-SHOW         ]    -          - Node  74 - Lock - Side Door
Fri. 12/06/2019 03:19:16 p.m. : [ZW-SHOW         ]    -          - Node  81 - Lock - Terrace Door
Fri. 12/06/2019 03:19:16 p.m. : [ZW-SHOW         ]    - Repeater - Node  86 - Tstat - Ensuite FP
Fri. 12/06/2019 03:19:16 p.m. : [ZW-SHOW         ] Node  85 - Tstat - LR FP has 1 association group
Fri. 12/06/2019 03:19:17 p.m. : [ZW-SHOW         ]    Associations for group 001 of ZW085_1 Tstat - LR FP
Fri. 12/06/2019 03:19:17 p.m. : [ZW-SHOW         ]    Max Associations = 1
Fri. 12/06/2019 03:19:17 p.m. : [ZW-SHOW         ]       - Node   1 - [This ISY]
Fri. 12/06/2019 03:19:17 p.m. : [ZW-SHOW         ] ----------------------------------------------
Am I missing something or is this a bit of missing support for this device?
Edited by glarsen
