glarsen Posted December 12, 2019 Share Posted December 12, 2019 Hi James, I have a couple of TH6320ZW2003 Honeywell thermostats. While they do allow setting heat/cool setpoints in .5 degree increments (either C or F) apparently the ZWave support for fractional degrees is either broken or missing according to UDI. If you try a fractional settting, the only result is a heat setting of 4.5. Is there any logic Agave can use to identify these devices and only allow full degree changes? Thanks! Link to comment
James Peterson Posted January 7, 2020 Share Posted January 7, 2020 On 12/12/2019 at 2:05 PM, glarsen said: Hi James, I have a couple of TH6320ZW2003 Honeywell thermostats. While they do allow setting heat/cool setpoints in .5 degree increments (either C or F) apparently the ZWave support for fractional degrees is either broken or missing according to UDI. If you try a fractional settting, the only result is a heat setting of 4.5. Is there any logic Agave can use to identify these devices and only allow full degree changes? Thanks! Sorry for late response. This may be possible. Please send me a debug log explaining everything that is happening and a full node dump of the device. http://agaveha.com/docs/node-dump/ Link to comment
glarsen Posted January 7, 2020 Author Share Posted January 7, 2020 6 hours ago, James Peterson said: Sorry for late response. This may be possible. Please send me a debug log explaining everything that is happening and a full node dump of the device. http://agaveha.com/docs/node-dump/ Thanks, no worries, will do shortly. Link to comment
