Turn off backlight on MAIN button when that load is part of a scene
Things going well thanks to the help here - one small niggling thing: on the 8 button keypad, can I set the MAIN key light off even though the load is on from scene?
For example, my KITCHEN MED. light scene controls the levels for four light circuits - one load of the four is the load MAIN button. To me, it doesn't look right that the button for MAIN is illuminated at the same time keypad D (KITCHEN MED scene) is active and illuminated.
It's probably fairly simple...
I looked into the COMMAND option for the button (both at the scene level and the controller level), but Backlight already indicates 0/0
If the load is on the keypad button will be lit.
You can create a separate scene for just the light that's on the load
Well I have four different loads in the kitchen I want to created bright, medium and low scenes
one of 4 is the main button so I guess I cannot do
thanka
