3 Way Switch with Two Motion Sensors - motion Off program not working
TLDR: My MotionTimer program isn't turning off my staircase lights scene after the motion sensors have sent off signals.
Background:
I have a virtual 3 way switch that controls my staircase lights via a scene: sStairsLights.
  • The "Stairs_Lights_Load" dimmer switch carries the load physically to the light
  • The "Stairs_Lights_Remote" is configured to remotely turn on/off the scene.
sStairsLights
I have two motion sensors (top of staircase landing & bottom of staircase) that are programmed to turn on/off the sStairsLights, UNLESS either dimmer switch is physically switched on. If either switch is switched on and not switched off, the motion programs are disabled so the lights stay on until either switch is switched off, at which point the motion programs are enabled again.
This is done via a few motion timer enabler programs ("pStairs_MotionTimer_Enable" and "pStairs_MotionTimer_Enable/Disable"), which in turn enable/disable the folder "enabler" containing the "pStairs_MotionOn" and "pStairs_MotionTimer" programs:
pStairs_MotionTimer_Enable - [ID 001C][Parent 0006][Not Enabled][Run At Startup]
        Set Program 'pStairs_MotionTimer_Enable' To Run At Startup
        Set Program 'pStairs_MotionTimer_Enable' To Not Run At Startup
pStairs_MotionTimer_Enable/Disable - [ID 001A][Parent 0006]
             'Inside / Stairs / Stairs_Lights_Load' is switched On
          Or 'Inside / Stairs / Stairs_Lights_Remote' is switched On
    And (
             'Inside / Stairs / Stairs_Lights_Load' is not switched Off
         And 'Inside / Stairs / Stairs_Lights_Remote' is not switched Off
        Run Program 'pStairs_MotionTimer_Enable' (Else Path)
        Run Program 'pStairs_MotionTimer_Enable' (Then Path)
FOLDER: enabler
enabler - [ID 001D][Parent 0006]
Folder Conditions for 'enabler'
        Program 'pStairs_MotionTimer_Enable' is True
pStairs_MotionOn
pStairs_MotionOn - [ID 0016][Parent 001D]
        'Inside / Stairs / _Sensor_Motion' is switched On
     Or 'Inside / Stairs / Staircase_Sensor_Motion' is switched On
    And 'Inside / Stairs / Stairs_Lights_Load' Status is Off
        Set 'Inside / Stairs / sStairsLights' On
pStairs_MotionTimer
pStairs_MotionTimer - [ID 0019][Parent 001D]
        'Inside / Stairs / _Sensor_Motion' is switched Off
     Or 'Inside / Stairs / Staircase_Sensor_Motion' is switched Off
    And 'Inside / Stairs / Staircase_Sensor_Motion' Status is Off
    And 'Inside / Stairs / _Sensor_Motion' Status is Off
        Wait  5 seconds
        Set 'Inside / Stairs / sStairsLights' Off
Everything works up until this last "pStairs_MotionTimer" program that's supposed to turn off the scene. It's set so that once the motion sensors send the OFF signal after the 30 second timeout, the program waits 5 seconds before turning the scene off. I can't figure out what's incorrect in my syntax but I have the lights successfully turning on when motion is sensed, but I cannot get them to turn off.
Under the program summary view, I can see the pStairs_MotionOn program runs when motion is sensed, and then 30 second later I can see the pStairs_MotionTimer has run but the lights don't turn off. Any idea what I've done wrong?
Thank you!
Edited by newpixelwheelhouse
No, it isn't.  It's set so that once one of the motion sensors OR the other sensor AND...AND...  Are the two sensors close by?  Are they typically triggered within seconds of each other?  It seems to me that this set of conditions runs the risk that could run FALSE (else path) pretty regularly, including an interruption of the 5-second wait.  My concern is that this is more complicated than it needs to be and introduces unexpected results.
For your upstairs motion timer program, why not:
if
 'Inside / Stairs / _Sensor_Motion' status is Off
     and 'Inside / Stairs / Staircase_Sensor_Motion' status is Off
then
same
else
same
if
then
same
else
same
I was under the impression that a "control" trigger needs to be in the if statement in order to trigger the program to run. That's why I had the "if either switch is switched off" part in addition to both sensors' status is off, then timer > turn off.
Thank you very much, this appears to solve my issue!
No.  While "control" conditions will trigger a program, so will most other conditions, including "status" conditions.  The real question is WHEN will a condition trigger a program.
Make sure you understand the priorities of the logical conditions "and" and "or".  Because of those priorities, the logic would evaluate as (parentheses added for explanation purposes):
('Inside / Stairs / _Sensor_Motion' is switched Off)
     Or
('Inside / Stairs / Staircase_Sensor_Motion' is switched Off
    And 'Inside / Stairs / _Sensor_Motion' Status is Off)
It is not unlike a math problem such as 3+2*4*4.  Is the answer 96?  Is the answer 35?  Something else?  In logic, like math, some operations occur before others.
Edited by oberkc
     Or
I see, this will definitely help me figure out some other issues I'm running into on my own before coming back to the forums for help.
Much appreciated!
      37.5k
      375.5k
