February 2, 20206 yr Trying to add Z-Wave tilt sensor, specifically "Ecolink TILT-ZWAVE2.5-ECO" Using 994i with Z module ISY Firmware version 5.0.16C Z-Wave version: 6.81.00 Tried the following with cover removed: 1. Set to exclude in ISY, "add battery", the ISY stopped listening 2. removed battery 3. Set to add mode in ISY 4. Insert battery, stopped listening, included log below Sun 02/02/2020 05:38:01 PM : [UZW-CMD 2 ] Start Exclude Sun 02/02/2020 05:38:01 PM : Listening for Z-Wave devices to remove from the network Sun 02/02/2020 05:38:09 PM : Removing Z-Wave devices stopped Sun 02/02/2020 05:38:10 PM : Device 3 excluded from Z-Wave network Sun 02/02/2020 05:38:39 PM : [UZW-CMD 1 ] Start Include Sun 02/02/2020 05:38:39 PM : Listening for Z-Wave devices to add to the network Sun 02/02/2020 05:38:45 PM : Z-Wave device detected, retrieving info 2 Sun 02/02/2020 05:38:45 PM : Z-Wave device detected, retrieving info 3 Sun 02/02/2020 05:38:45 PM : Z-Wave device detected, retrieving info 5 Sun 02/02/2020 05:38:45 PM : Adding Z-Wave devices stopped Sun 02/02/2020 05:38:46 PM : Device 4 of type 4.7.1 included into Z-Wave network Sun 02/02/2020 05:38:46 PM : [ZWAVE-ADD-NODE] Cannot add primary node for 4.0 Sun 02/02/2020 05:38:46 PM : [ZWAVE-ADD-NODE] Device 4.0 not added Sun 02/02/2020 05:38:46 PM : Add Node failed: Cannot create primary node for new device Anybody have success? Edited February 2, 20206 yr by copart
June 9, 20206 yr Did you ever figure this out? I'm not sure if I'm having the same issue yet, but I can't seem to add two z-wave devices, different brands and one is a new ecolink window/door sensor. They never show up. I haven't seen anything useful in the logs yet -- trying to generate that now. I'm running the same versions you are.
