2.4.12 - Move line up/down errors
While editing a program:
When I move a line up or down And changes to Or and vice versa.
When a line is highlighted FastOn changes to On in the editing window.
After the program is saved I don't see the same affects.
Original program:
       Control 'Patio' is switched Fast On
       Set  Scene 'Outside Lights' On
       Set  Scene 'Indoor Lights' On
       Set 'Patio' Fast On
       Set 'Sidewalk Flood' Fast On
       Set 'Driveway' Fast On
New line added:
    Or Control 'Patio' is switched On
       Set 'Patio' Fast On
Lines exchanged, Or changes to And, and visa versa:
   And Control 'Patio' is switched Fast On
       Set 'Patio' Fast On
After selecting the line to correct the And/Or FastOn is changed to On. I don't see this with other commands.
       Set 'Patio' Fast On
Rand
ATF? A man can always use more alcohol, tobacco and firearms.
Shoot, I meant to compliment you guys about how difficult it is becoming to find errors :D
Rand
Chris,
If you create and save the original program I displayed, and then try to add an If 'Or control X is switched on' I hope you will see the error. I had created a trigger based on FastOn and wanted to add an Or On condition based on the same switch as the FastOn. So my roommates wouldn't have to remember twice quickly. And then I wanted to move the If On above the If FastOn. Does that make sense?
It may be that you have to create and save and quit and possibly restart the Console. Then attempt the changes I suggest.
Rand
Thanks Rand,
1) And/Or
The And/Or swapping looks odd, but is working correctly.
An And/Or is assigned to each line as you add it. If its the first entry, or the first entry after an open parentheses then it is not shown because it is not used. When you move the line down, it then appears because it is used.
In other words, you see:
But its the same as:
Swap the lines:
You see:
2) Fast On changed to On
I tried doing this for awhile, and managed one time to get it to do this by some random combination of what you mentioned. I can't reliably reproduce it, but I'll see if I can make a fix for it.
It took me so long to reproduce this, I'm surprised you found it in the first place.
Rand,
Ok its time to get out FRAPs (FRAPs may only work with DirectX programs) or some screen recorder and record the screen as you do this so there is a movie of whats going on.
Thanks Rand,
Oh, you know me :wink:
I found a way to reproduce this problem consistently, and have fixed the problem.
Good Job! Sorry I wasn't here to help. I hope you didn't stay up all night :D
Thanks Rand,
1) And/Or
Swap the lines:
You see:
After I Saved that program exchanging lines keeps the And/Or as set for the second line. I prefer that method.
I thought that as I was editing that I had set both lines to Or and watched them toggle as I exchanged them. Now I can't reproduce it :oops:
Well, I'll keep trying :D
Thank you for your time,
Rand
