AerisWeather Eto to variable incorrect
TJF1960
Hello   @bpwwer
I am seeing correct GV20 (Forecast Eto) numbers from Aeris in Polyglote being transferred to ISY Aeris node page. When I transfer the Eto figure to a variable I see random numbers appear in the variable. For instance when this program is manually ran:
Eto Test Var - [ID 0051][Parent 0254]
        $iEto  = 'PolyGlot / AerisWeather / AERIS Weather / Forecast 0' Evapotranspiration mm/day
The Forecast 0 GV20 in Poly dashboard shows an amount of 0.172, in the admin console ISY forecast 0 page shows 0.172 in/day. The variable however shows 4.369
I tried this with each Forecast 0-5 and different values would appear.
*** I think I just figured out what is going on. The values showing up in variables appear to be mm/day as opposed to in/day. Is this possible?
I have imperial selected for this node and in/day is indicated on the ISY Aeris admin page.
Tim
Link to comment
Share on other sites
Yes, it's doing the conversion because it looks like that's what you asked it to put in the variable.
I believe you can select which units to use (mm/day or inches/day) when you assign it to a variable (at least you should be able to).
Link to comment
I don't see how to. mm/day is printed after the drop down and appears to be fixed text.
I am trying to figure out how to copy screen on win10 to paste a screen shot but its not working.
Tim
Link to comment
Hmm, yeah, I see that too. It might something I have wrong in the profile or maybe the ISY isn't handling those specific units correctly.  I believe the inches/day is a new UOM.
Link to comment
      36.6k
      367.9k
