dpayeur Posted September 12, 2009 Posted September 12, 2009 Hello all (first post here), I have a new ISY-99i (2.7) and I love it! After fighting with mControl, HouseLinc and some home made solutions using SDM, the ISY works like a charm and does what you expect it would. Thank you UD. Now for a small problem ... I want my bedroom table lamp to turn off in two steps, to allow me to put my book down before it goes full off. Something like this: if(lamp is ON) { set lamp = 50% wait 10 seconds if(lamp is 50%) { set lamp = OFF } } I add the first 'if' to make sure that if the lamp is already OFF it doesn't go to 50% for a few seconds and then back OFF. And the second 'if' to allow me to 'override' by turning it back ON during the wait to read a bit longer. To do that with the ISY, I made two programs: "Bedroom OFF" A like this(approx): If Time Is 10:15:00pm And Status 'Lamp' is ON Then Set 'lamp' 50% Wait 10 seconds Run Program 'Bedroom B' (Then Path) Else - No Actions And "Bedroom B" like this (approx): If Status 'Lamp' is 50% Then Set 'lamp' Off Else - No Actions The problem is the 'Wait' command does not seem to work. It does wait because the status of program A says it's running for a little while but it goes right on and run program B, while waiting. I found some references to that in the forums but no solutions. Is there a (better) way to accomplish this simple need ? thank you Donald
ergodic Posted September 12, 2009 Posted September 12, 2009 Hi and welcome I cobbled together a pair of sample program that uses one switch to control the kind of scene change you want. "U/S Office Cans" is the light being controlled and "U/S Hall Aux." is the controller for the program. Just what was handy - translate for your own needs If Status 'U/S Office Cans' > 49% And Control 'U/S Hall Aux.' is switched On Then Run Program 'Program2' (Then Path) Else - No Actions - (To add one, press 'Action') If - No Conditions - (To add one, press 'Schedule' or 'Condition') Then Set 'U/S Office Cans' 50% Wait 10 seconds Set 'U/S Office Cans' Off Else - No Actions - (To add one, press 'Action') You need two programs, though not I believe for the reason you think. If you collapse Program2's logic into Program1's Then part, you end up canceling your own program after the initial change down to 50% (though I'll confess I'm hard-pressed to explain exactly why that happens.) Granularizing all the logic in another program prevents that. I believe there is also a restriction that a tail Wait in an ISY clause does nothing, though again I could be fuzzy on this; I don't try to use that sort of thing much. Programmers look at the ISY languange and see programming constructs, but it is really a very nice, simple, real-time, largely stateless, instantiated, applicative language. Don't try to force too much out of one program and it gets easier. While sometimes useful, if you start looking for ways to emulate nested ifs, variables, etc. it gets ugly very fast. HTH
dpayeur Posted September 13, 2009 Author Posted September 13, 2009 ergodic, thanks for your reply. But what happens if the light goes to 50% and I bring it back up to ON during the 10 secs wait. It'll force it to OFF after the wait. I really need the program to check that the lamp is still at 50% before it turns it OFF... thanks Donald
ergodic Posted September 13, 2009 Posted September 13, 2009 The simplest is to just create another program that watches for the control/status change you are interested in, and executes a Stop Program on when it sees that happen. If isn't running it won't hurt anything.
Algorithm Posted September 14, 2009 Posted September 14, 2009 Hello Donald, In your first program, when the lamp is set to 50%, the Status 'Lamp' is On condition becomes false (On = 100%), and therefore as soon as the Wait line is reached, the If is re-evaluated and the program switches from running the Then to running the Else. To overcome this, change that line to Status 'Lamp' is Not Off. Also, in order to have program B's If evaluated when called from program A, change the line in program A's Then to run program B's If rather than its Then. Finally, the reason program B runs immediately is because as soon as the lamp is set to 50%, program B's If becomes true. To prevent program B from running automatically, clear its Enabled checkbox. Program B will then only run when called from another program. "Bedroom OFF" A: If Time Is 10:15:00pm And Status 'Lamp' is Not Off Then Set 'lamp' 50% Wait 10 seconds Run Program 'Bedroom B' (If) Else - No Actions "Bedroom B": (NOT Enabled) If Status 'Lamp' is 50% Then Set 'lamp' Off Else - No Actions
dpayeur Posted September 15, 2009 Author Posted September 15, 2009 Thanks for the replies. I got it working now. I was stomped by the program's ability to quit if its conditions turn false during the execution ... I guess I had too much of a 'procedural' programming minding. Thanks to all Donald
