io_guy Posted May 26, 2020 Posted May 26, 2020 Trying to login to the portal and/or developer portal and/or my.isy after about 6 months. None work and all tell me they don't recognize the various usernames (so I can't reset anything). Did I miss something?
bmercier Posted May 26, 2020 Posted May 26, 2020 On 5/26/2020 at 1:15 AM, io_guy said: Trying to login to the portal and/or developer portal and/or my.isy after about 6 months. None work and all tell me they don't recognize the various usernames (so I can't reset anything). Did I miss something? Expand Login to my.isy.io has not changed, it should be working. Can you reset yout password? Other UDI sites have changed so that it uses my.isy.io credentials (using oAuth).
io_guy Posted May 26, 2020 Author Posted May 26, 2020 Nope, my previous login says it doesn't exist when I try a reset.
bmercier Posted May 26, 2020 Posted May 26, 2020 On 5/26/2020 at 2:41 AM, io_guy said: Nope, my previous login says it doesn't exist when I try a reset. Expand Can you pm me your uuid? I'll see if I can find something. Are you using echo or GH? And if so, do they still work?
