NodeLink WeatherFlow Heartbeat Issue!
@io_guy    First of all... I'm sorry that I have been throwing a bunch of NodeLink issues at you lately, but over the last few weeks I have been trying to setup NodeLink (new non-mono version) at two locations (home and cottage) and I also updated my Raspberry Pi's to Buster.
Background:
On my Home setup, I have 2 Venstar ColorTouch thermostats; a DSC alarm with EnvisaLink; a WeatherFlow station (only using the Air so far); and I'm using the Relay Server, Network Monitor and Additional ISY Data devices. Other than a question I posed (on another thread) about how to change the Venstar nodes to Celsius from Fahrenheit, everything seems to be working well.
At my Cottage setup, I have 1 Venstar ColorTouch thermostat; a DSC alarm with EnvisaLink; a RainMachine HD-16 system (on another thread I explained that I am having an issue with the Weather node on the ISY); a WeatherFlow station (Air and Sky); and I'm using the Relay Server, Network Monitor and Additional ISY Data devices.
This morning I setup the WeatherFlow station with the Air and Sky devices, and then created the new Device in NodeLink. In NodeLink. Initially, on the WeatherFlow NodeLink tab there was no data and the nodes were not created on the ISY. I then restarted Nodelink and the Sky data populated in the NodeLink tab and the node was created on the ISY. The Air device had no data in NodeLink and the node was not created in the ISY! I restarted NodeLink again and this time the reverse occurred... the WeatherFlow tab, in NodeLink, had data populated for the Air, but nothing for the Sky! Also this time the Air node was now created on the ISY.  I then rebooted the ISY and restarted NodeLink. In NodeLink, on the WeatherFlow tab, initially only the Air populated but after hitting refresh the Sky also populated. Now, on the ISY, the WeatherFlow nodes data seems to be getting refreshed however the Heartbeats are erratic! Most times, I can see the heartbeat change (e.g. 1 to -1) but then immediately change back to 1... however, sometimes one of the two nodes will actually have the heartbeat change and stay changed!
I am attaching the log from the time I rebooted the ISY and restarted NodeLink... There sure seem to be a lot of log items!
2020-07-15 13:28:32 - Relay Server Error: Error: OnClientConnection - Cannot access a disposed object.
Object name: 'System.Net.Sockets.Socket'.
2020-07-15 13:28:32 - DSC Error: Data Arrival Init - Cannot access a disposed object.
Object name: 'System.Net.Sockets.Socket'. [dsc1]
2020-07-15 13:28:33 - ISY resolved to 10.0.2.141 (5.0.16C)
2020-07-15 13:28:33 - ISY Node Server config detected (profile 1)
2020-07-15 13:28:36 - Relay Server: Started on port 2405
2020-07-15 13:28:37 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834116,0.00,0]}[flow1]
2020-07-15 13:28:37 - RainMachine: Response data - {"access_token": "f1af91cf3e4f1ad29df9235ee02e31789ebed724071db87bffa1e655", "checksum": "42affe03de83a691ef7807ffd794ee0405080011d2166334662f1cb9b8cfaf5c4baba6236b468a5eace90812b20d69a1465efdebffa0c195", "expires_in": 157680000, "expiration": "Mon, 14 Jul 2025 17:28:37 GMT", "statusCode": 0}(P) [rain1]
2020-07-15 13:28:39 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834119,0.00,0]}[flow1]
2020-07-15 13:28:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834119,0.00,0]}[flow1]
2020-07-15 13:28:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1623,"rssi":-35,"timestamp":1594834119,"reset_flags":"PIN,SFT","seq":160,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:28:43 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834122,0.00,0]}[flow1]
2020-07-15 13:28:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"device_status","hub_sn":"HB-00010608","timestamp":1594834124,"uptime":54484,"voltage":3.50,"firmware_revision":20,"rssi":-24,"hub_rssi":0,"sensor_status":4,"debug":0}[flow1]
2020-07-15 13:28:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"obs_air","hub_sn":"HB-00010608","obs":[[1594834124,986.20,25.23,43,0,0,3.502,1]],"firmware_revision":20}[flow1]
2020-07-15 13:28:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834125,0.00,0]}[flow1]
2020-07-15 13:28:46 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834125,0.00,0]}[flow1]
2020-07-15 13:28:49 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834128,0.00,0]}[flow1]
2020-07-15 13:28:50 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1633,"rssi":-36,"timestamp":1594834129,"reset_flags":"PIN,SFT","seq":161,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:28:51 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834131,0.00,0]}[flow1]
2020-07-15 13:28:52 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834131,0.00,0]}[flow1]
2020-07-15 13:28:55 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834134,0.00,0]}[flow1]
2020-07-15 13:28:57 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834137,0.00,0]}[flow1]
2020-07-15 13:28:58 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834137,0.00,0]}[flow1]
2020-07-15 13:29:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1643,"rssi":-36,"timestamp":1594834139,"reset_flags":"PIN,SFT","seq":162,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:29:01 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834140,0.00,0]}[flow1]
2020-07-15 13:29:03 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834143,0.00,0]}[flow1]
2020-07-15 13:29:06 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834146,0.00,0]}[flow1]
2020-07-15 13:29:07 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834146,0.00,0]}[flow1]
2020-07-15 13:29:09 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834149,0.00,0]}[flow1]
2020-07-15 13:29:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834149,0.00,0]}[flow1]
2020-07-15 13:29:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1653,"rssi":-35,"timestamp":1594834149,"reset_flags":"PIN,SFT","seq":163,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:29:12 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834152,0.00,0]}[flow1]
2020-07-15 13:29:13 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834152,0.00,0]}[flow1]
2020-07-15 13:29:16 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834155,0.00,0]}[flow1]
2020-07-15 13:29:18 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834158,0.00,0]}[flow1]
2020-07-15 13:29:19 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834158,0.00,0]}[flow1]
2020-07-15 13:29:20 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1663,"rssi":-36,"timestamp":1594834159,"reset_flags":"PIN,SFT","seq":164,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:29:22 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834161,0.00,0]}[flow1]
2020-07-15 13:29:24 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834164,0.00,0]}[flow1]
2020-07-15 13:29:25 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834164,0.00,0]}[flow1]
2020-07-15 13:29:28 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834167,0.00,0]}[flow1]
2020-07-15 13:29:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1673,"rssi":-36,"timestamp":1594834169,"reset_flags":"PIN,SFT","seq":165,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:29:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834170,0.00,0]}[flow1]
2020-07-15 13:29:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"device_status","hub_sn":"HB-00010608","timestamp":1594834172,"uptime":77050,"voltage":3.46,"firmware_revision":43,"rssi":-32,"hub_rssi":-33,"sensor_status":0,"debug":0}[flow1]
2020-07-15 13:29:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"obs_sky","hub_sn":"HB-00010608","obs":[[1594834172,107,0.00,0.000000,0.00,0.00,0.00,0,3.461,1,0,null,0,3]],"firmware_revision":43}[flow1]
2020-07-15 13:29:34 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834173,0.00,0]}[flow1]
2020-07-15 13:29:36 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834176,0.00,0]}[flow1]
2020-07-15 13:29:37 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834176,0.00,0]}[flow1]
2020-07-15 13:29:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834179,0.00,0]}[flow1]
2020-07-15 13:29:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1683,"rssi":-37,"timestamp":1594834179,"reset_flags":"PIN,SFT","seq":166,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:29:42 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834182,0.00,0]}[flow1]
2020-07-15 13:29:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"device_status","hub_sn":"HB-00010608","timestamp":1594834184,"uptime":54544,"voltage":3.50,"firmware_revision":20,"rssi":-22,"hub_rssi":0,"sensor_status":4,"debug":0}[flow1]
2020-07-15 13:29:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"obs_air","hub_sn":"HB-00010608","obs":[[1594834184,986.20,25.29,43,0,0,3.502,1]],"firmware_revision":20}[flow1]
2020-07-15 13:29:46 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834185,0.00,0]}[flow1]
2020-07-15 13:29:48 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834188,0.00,0]}[flow1]
2020-07-15 13:29:49 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834188,0.00,0]}[flow1]
2020-07-15 13:29:50 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1693,"rssi":-40,"timestamp":1594834189,"reset_flags":"PIN,SFT","seq":167,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:29:51 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834191,0.00,0]}[flow1]
2020-07-15 13:29:52 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834191,0.00,0]}[flow1]
2020-07-15 13:29:54 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834194,0.00,0]}[flow1]
2020-07-15 13:29:57 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834197,0.00,0]}[flow1]
2020-07-15 13:29:58 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834197,0.00,0]}[flow1]
2020-07-15 13:30:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1703,"rssi":-35,"timestamp":1594834199,"reset_flags":"PIN,SFT","seq":168,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:30:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834200,0.00,0]}[flow1]
2020-07-15 13:30:01 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834200,0.00,0]}[flow1]
2020-07-15 13:30:03 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834203,0.00,0]}[flow1]
2020-07-15 13:30:07 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834206,0.00,0]}[flow1]
2020-07-15 13:30:09 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834209,0.00,0]}[flow1]
2020-07-15 13:30:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1713,"rssi":-34,"timestamp":1594834209,"reset_flags":"PIN,SFT","seq":169,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:30:13 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834212,0.00,0]}[flow1]
2020-07-15 13:30:16 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834215,0.00,0]}[flow1]
2020-07-15 13:30:19 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834218,0.00,0]}[flow1]
2020-07-15 13:30:20 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1723,"rssi":-35,"timestamp":1594834219,"reset_flags":"PIN,SFT","seq":170,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:30:21 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834221,0.00,0]}[flow1]
2020-07-15 13:30:24 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834224,0.00,0]}[flow1]
2020-07-15 13:30:27 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834227,0.00,0]}[flow1]
2020-07-15 13:30:28 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834227,0.00,0]}[flow1]
2020-07-15 13:30:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1733,"rssi":-38,"timestamp":1594834229,"reset_flags":"PIN,SFT","seq":171,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:30:31 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834230,0.00,0]}[flow1]
2020-07-15 13:30:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"device_status","hub_sn":"HB-00010608","timestamp":1594834232,"uptime":77110,"voltage":3.46,"firmware_revision":43,"rssi":-32,"hub_rssi":-33,"sensor_status":0,"debug":0}[flow1]
2020-07-15 13:30:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"obs_sky","hub_sn":"HB-00010608","obs":[[1594834232,112,0.00,0.000000,0.00,0.00,0.00,0,3.461,1,0,null,0,3]],"firmware_revision":43}[flow1]
2020-07-15 13:30:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834233,0.00,0]}[flow1]
2020-07-15 13:30:36 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834236,0.00,0]}[flow1]
2020-07-15 13:30:37 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834236,0.00,0]}[flow1]
2020-07-15 13:30:39 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834239,0.00,0]}[flow1]
2020-07-15 13:30:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834239,0.00,0]}[flow1]
2020-07-15 13:30:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1743,"rssi":-35,"timestamp":1594834239,"reset_flags":"PIN,SFT","seq":172,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:30:42 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834242,0.00,0]}[flow1]
2020-07-15 13:30:43 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834242,0.00,0]}[flow1]
2020-07-15 13:30:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"device_status","hub_sn":"HB-00010608","timestamp":1594834245,"uptime":54604,"voltage":3.50,"firmware_revision":20,"rssi":-24,"hub_rssi":0,"sensor_status":4,"debug":0}[flow1]
2020-07-15 13:30:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"obs_air","hub_sn":"HB-00010608","obs":[[1594834245,986.20,25.32,43,0,0,3.503,1]],"firmware_revision":20}[flow1]
2020-07-15 13:30:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834245,0.00,0]}[flow1]
2020-07-15 13:30:48 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834248,0.00,0]}[flow1]
2020-07-15 13:30:51 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834251,0.00,0]}[flow1]
2020-07-15 13:30:52 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834251,0.00,0]}[flow1]
2020-07-15 13:30:54 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834254,0.00,0]}[flow1]
2020-07-15 13:30:55 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834254,0.00,0]}[flow1]
2020-07-15 13:30:58 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834257,0.00,0]}[flow1]
2020-07-15 13:31:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1763,"rssi":-36,"timestamp":1594834259,"reset_flags":"PIN,SFT","seq":174,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:31:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834260,0.00,0]}[flow1]
2020-07-15 13:31:01 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834260,0.00,0]}[flow1]
2020-07-15 13:31:03 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834263,0.00,0]}[flow1]
2020-07-15 13:31:06 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834266,0.00,0]}[flow1]
2020-07-15 13:31:07 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834266,0.00,0]}[flow1]
2020-07-15 13:31:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834269,0.00,0]}[flow1]
2020-07-15 13:31:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1773,"rssi":-36,"timestamp":1594834269,"reset_flags":"PIN,SFT","seq":175,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:31:12 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834272,0.00,0]}[flow1]
2020-07-15 13:31:13 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834272,0.00,0]}[flow1]
2020-07-15 13:31:15 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834275,0.00,0]}[flow1]
2020-07-15 13:31:18 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834278,0.00,0]}[flow1]
2020-07-15 13:31:19 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834278,0.00,0]}[flow1]
2020-07-15 13:31:20 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1783,"rssi":-36,"timestamp":1594834279,"reset_flags":"PIN,SFT","seq":176,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:31:21 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834281,0.00,0]}[flow1]
2020-07-15 13:31:22 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834281,0.00,0]}[flow1]
2020-07-15 13:31:24 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834284,0.00,0]}[flow1]
2020-07-15 13:31:27 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834287,0.00,0]}[flow1]
2020-07-15 13:31:28 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834287,0.00,0]}[flow1]
2020-07-15 13:31:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1793,"rssi":-35,"timestamp":1594834289,"reset_flags":"PIN,SFT","seq":177,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:31:31 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834290,0.00,0]}[flow1]
2020-07-15 13:31:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"device_status","hub_sn":"HB-00010608","timestamp":1594834292,"uptime":77170,"voltage":3.46,"firmware_revision":43,"rssi":-31,"hub_rssi":-31,"sensor_status":0,"debug":0}[flow1]
2020-07-15 13:31:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"obs_sky","hub_sn":"HB-00010608","obs":[[1594834292,116,0.00,0.000000,0.00,0.00,0.00,0,3.461,1,0,null,0,3]],"firmware_revision":43}[flow1]
2020-07-15 13:31:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834293,0.00,0]}[flow1]
2020-07-15 13:31:34 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834293,0.00,0]}[flow1]
2020-07-15 13:31:37 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834296,0.00,0]}[flow1]
2020-07-15 13:31:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1803,"rssi":-34,"timestamp":1594834299,"reset_flags":"PIN,SFT","seq":178,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:31:42 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834302,0.00,0]}[flow1]
2020-07-15 13:31:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"device_status","hub_sn":"HB-00010608","timestamp":1594834304,"uptime":54664,"voltage":3.50,"firmware_revision":20,"rssi":-37,"hub_rssi":0,"sensor_status":4,"debug":0}[flow1]
2020-07-15 13:31:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"obs_air","hub_sn":"HB-00010608","obs":[[1594834304,986.20,25.33,43,0,0,3.503,1]],"firmware_revision":20}[flow1]
2020-07-15 13:31:46 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834305,0.00,0]}[flow1]
2020-07-15 13:31:49 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834308,0.00,0]}[flow1]
2020-07-15 13:31:50 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1813,"rssi":-37,"timestamp":1594834309,"reset_flags":"PIN,SFT","seq":179,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:31:51 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834311,0.00,0]}[flow1]
2020-07-15 13:31:52 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834311,0.00,0]}[flow1]
2020-07-15 13:31:54 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834314,0.00,0]}[flow1]
2020-07-15 13:31:55 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834314,0.00,0]}[flow1]
2020-07-15 13:31:57 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834317,0.00,0]}[flow1]
2020-07-15 13:31:58 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834317,0.00,0]}[flow1]
2020-07-15 13:32:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1823,"rssi":-37,"timestamp":1594834319,"reset_flags":"PIN,SFT","seq":180,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:32:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834320,0.00,0]}[flow1]
2020-07-15 13:32:01 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834320,0.00,0]}[flow1]
2020-07-15 13:32:03 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834323,0.00,0]}[flow1]
2020-07-15 13:32:06 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834326,0.00,0]}[flow1]
2020-07-15 13:32:07 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834326,0.00,0]}[flow1]
2020-07-15 13:32:09 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834329,0.00,0]}[flow1]
2020-07-15 13:32:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834329,0.00,0]}[flow1]
2020-07-15 13:32:12 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834332,0.00,0]}[flow1]
2020-07-15 13:32:13 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834332,0.00,0]}[flow1]
2020-07-15 13:32:16 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834335,0.00,0]}[flow1]
2020-07-15 13:32:18 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834338,0.00,0]}[flow1]
2020-07-15 13:32:19 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834338,0.00,0]}[flow1]
2020-07-15 13:32:20 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1843,"rssi":-37,"timestamp":1594834339,"reset_flags":"PIN,SFT","seq":182,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:32:21 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834341,0.00,0]}[flow1]
2020-07-15 13:32:22 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834341,0.00,0]}[flow1]
2020-07-15 13:32:25 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834344,0.00,0]}[flow1]
2020-07-15 13:32:28 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834347,0.00,0]}[flow1]
2020-07-15 13:32:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1853,"rssi":-27,"timestamp":1594834349,"reset_flags":"PIN,SFT","seq":183,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:32:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834350,0.00,0]}[flow1]
2020-07-15 13:32:31 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834350,0.00,0]}[flow1]
2020-07-15 13:32:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"device_status","hub_sn":"HB-00010608","timestamp":1594834352,"uptime":77230,"voltage":3.46,"firmware_revision":43,"rssi":-33,"hub_rssi":-34,"sensor_status":0,"debug":0}[flow1]
2020-07-15 13:32:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"obs_sky","hub_sn":"HB-00010608","obs":[[1594834352,119,0.00,0.000000,0.00,0.00,0.00,0,3.461,1,0,null,0,3]],"firmware_revision":43}[flow1]
2020-07-15 13:32:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834353,0.00,0]}[flow1]
2020-07-15 13:32:34 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834353,0.00,0]}[flow1]
2020-07-15 13:32:36 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834356,0.00,0]}[flow1]
2020-07-15 13:32:37 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834356,0.00,0]}[flow1]
2020-07-15 13:32:39 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834359,0.00,0]}[flow1]
2020-07-15 13:32:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1863,"rssi":-27,"timestamp":1594834359,"reset_flags":"PIN,SFT","seq":184,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:32:42 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834362,0.00,0]}[flow1]
2020-07-15 13:32:43 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834362,0.00,0]}[flow1]
2020-07-15 13:32:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"device_status","hub_sn":"HB-00010608","timestamp":1594834364,"uptime":54724,"voltage":3.50,"firmware_revision":20,"rssi":-27,"hub_rssi":0,"sensor_status":4,"debug":0}[flow1]
2020-07-15 13:32:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"obs_air","hub_sn":"HB-00010608","obs":[[1594834364,986.20,25.36,43,0,0,3.502,1]],"firmware_revision":20}[flow1]
2020-07-15 13:32:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834365,0.00,0]}[flow1]
2020-07-15 13:32:46 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834365,0.00,0]}[flow1]
2020-07-15 13:32:48 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834368,0.00,0]}[flow1]
2020-07-15 13:32:49 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834368,0.00,0]}[flow1]
2020-07-15 13:32:50 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1873,"rssi":-28,"timestamp":1594834369,"reset_flags":"PIN,SFT","seq":185,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:32:51 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834371,0.00,0]}[flow1]
2020-07-15 13:32:52 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834371,0.00,0]}[flow1]
2020-07-15 13:32:54 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834374,0.00,0]}[flow1]
2020-07-15 13:32:55 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834374,0.00,0]}[flow1]
2020-07-15 13:32:57 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834377,0.00,0]}[flow1]
2020-07-15 13:33:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1883,"rssi":-28,"timestamp":1594834379,"reset_flags":"PIN,SFT","seq":186,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:33:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834380,0.00,0]}[flow1]
2020-07-15 13:33:01 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834380,0.00,0]}[flow1]
2020-07-15 13:33:03 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834383,0.00,0]}[flow1]
2020-07-15 13:33:04 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834383,0.00,0]}[flow1]
2020-07-15 13:33:07 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834386,0.00,0]}[flow1]
2020-07-15 13:33:09 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834389,0.00,0]}[flow1]
2020-07-15 13:33:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834389,0.00,0]}[flow1]
2020-07-15 13:33:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1893,"rssi":-28,"timestamp":1594834389,"reset_flags":"PIN,SFT","seq":187,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:33:12 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834392,0.00,0]}[flow1]
2020-07-15 13:33:15 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834395,0.00,0]}[flow1]
2020-07-15 13:33:16 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834395,0.00,0]}[flow1]
2020-07-15 13:33:19 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834398,0.00,0]}[flow1]
2020-07-15 13:33:21 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834401,0.00,0]}[flow1]
2020-07-15 13:33:22 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834401,0.00,0]}[flow1]
2020-07-15 13:33:24 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834404,0.00,0]}[flow1]
2020-07-15 13:33:25 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834404,0.00,0]}[flow1]
2020-07-15 13:33:27 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834407,0.00,0]}[flow1]
2020-07-15 13:33:28 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834407,0.00,0]}[flow1]
2020-07-15 13:33:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1913,"rssi":-27,"timestamp":1594834409,"reset_flags":"PIN,SFT","seq":189,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:33:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834410,0.00,0]}[flow1]
2020-07-15 13:33:31 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834410,0.00,0]}[flow1]
2020-07-15 13:33:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"device_status","hub_sn":"HB-00010608","timestamp":1594834412,"uptime":77290,"voltage":3.46,"firmware_revision":43,"rssi":-30,"hub_rssi":-32,"sensor_status":0,"debug":0}[flow1]
2020-07-15 13:33:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"obs_sky","hub_sn":"HB-00010608","obs":[[1594834412,123,0.00,0.000000,0.00,0.00,0.00,0,3.461,1,1,null,0,3]],"firmware_revision":43}[flow1]
2020-07-15 13:33:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834413,0.00,0]}[flow1]
2020-07-15 13:33:36 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834416,0.00,0]}[flow1]
2020-07-15 13:33:37 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834416,0.00,0]}[flow1]
2020-07-15 13:33:39 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834419,0.00,0]}[flow1]
2020-07-15 13:33:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834419,0.00,0]}[flow1]
2020-07-15 13:33:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1923,"rssi":-27,"timestamp":1594834419,"reset_flags":"PIN,SFT","seq":190,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:33:42 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834422,0.00,0]}[flow1]
2020-07-15 13:33:43 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834422,0.00,0]}[flow1]
2020-07-15 13:33:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"device_status","hub_sn":"HB-00010608","timestamp":1594834424,"uptime":54784,"voltage":3.50,"firmware_revision":20,"rssi":-28,"hub_rssi":0,"sensor_status":4,"debug":0}[flow1]
2020-07-15 13:33:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"obs_air","hub_sn":"HB-00010608","obs":[[1594834424,986.20,25.37,43,0,0,3.498,1]],"firmware_revision":20}[flow1]
2020-07-15 13:33:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834425,0.00,0]}[flow1]
2020-07-15 13:33:48 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834428,0.00,0]}[flow1]
2020-07-15 13:33:50 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1933,"rssi":-27,"timestamp":1594834429,"reset_flags":"PIN,SFT","seq":191,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:33:51 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834431,0.00,0]}[flow1]
2020-07-15 13:33:52 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834431,0.00,0]}[flow1]
2020-07-15 13:33:54 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834434,0.00,0]}[flow1]
2020-07-15 13:33:55 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834434,0.00,0]}[flow1]
2020-07-15 13:33:58 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834437,0.00,0]}[flow1]
2020-07-15 13:34:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1943,"rssi":-27,"timestamp":1594834439,"reset_flags":"PIN,SFT","seq":192,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:34:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834440,0.00,0]}[flow1]
2020-07-15 13:34:01 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834440,0.00,0]}[flow1]
2020-07-15 13:34:03 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834443,0.00,0]}[flow1]
2020-07-15 13:34:06 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834446,0.00,0]}[flow1]
2020-07-15 13:34:07 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834446,0.00,0]}[flow1]
2020-07-15 13:34:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834449,0.00,0]}[flow1]
2020-07-15 13:34:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1953,"rssi":-27,"timestamp":1594834449,"reset_flags":"PIN,SFT","seq":193,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:34:12 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834452,0.00,0]}[flow1]
2020-07-15 13:34:13 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834452,0.00,0]}[flow1]
2020-07-15 13:34:15 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834455,0.00,0]}[flow1]
2020-07-15 13:34:16 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834455,0.00,0]}[flow1]
2020-07-15 13:34:18 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834458,0.00,0]}[flow1]
2020-07-15 13:34:19 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834458,0.00,0]}[flow1]
2020-07-15 13:34:20 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1963,"rssi":-26,"timestamp":1594834459,"reset_flags":"PIN,SFT","seq":194,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:34:21 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834461,0.00,0]}[flow1]
2020-07-15 13:34:22 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834461,0.00,0]}[flow1]
2020-07-15 13:34:25 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834464,0.00,0]}[flow1]
2020-07-15 13:34:27 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834467,0.00,0]}[flow1]
2020-07-15 13:34:28 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834467,0.00,0]}[flow1]
2020-07-15 13:34:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1973,"rssi":-27,"timestamp":1594834469,"reset_flags":"PIN,SFT","seq":195,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:34:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834470,0.00,0]}[flow1]
2020-07-15 13:34:31 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834470,0.00,0]}[flow1]
2020-07-15 13:34:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"device_status","hub_sn":"HB-00010608","timestamp":1594834472,"uptime":77350,"voltage":3.46,"firmware_revision":43,"rssi":-34,"hub_rssi":-34,"sensor_status":0,"debug":0}[flow1]
2020-07-15 13:34:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"obs_sky","hub_sn":"HB-00010608","obs":[[1594834472,127,0.00,0.000000,0.00,0.00,0.00,0,3.461,1,1,null,0,3]],"firmware_revision":43}[flow1]
2020-07-15 13:34:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834473,0.00,0]}[flow1]
2020-07-15 13:34:34 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834473,0.00,0]}[flow1]
2020-07-15 13:34:37 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834476,0.00,0]}[flow1]
2020-07-15 13:34:39 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834479,0.00,0]}[flow1]
2020-07-15 13:34:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834479,0.00,0]}[flow1]
2020-07-15 13:34:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1983,"rssi":-30,"timestamp":1594834479,"reset_flags":"PIN,SFT","seq":196,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:34:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"device_status","hub_sn":"HB-00010608","timestamp":1594834484,"uptime":54844,"voltage":3.50,"firmware_revision":20,"rssi":-24,"hub_rssi":0,"sensor_status":4,"debug":0}[flow1]
2020-07-15 13:34:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"obs_air","hub_sn":"HB-00010608","obs":[[1594834484,986.20,25.39,43,0,0,3.500,1]],"firmware_revision":20}[flow1]
2020-07-15 13:34:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834485,0.00,0]}[flow1]
2020-07-15 13:34:46 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834485,0.00,0]}[flow1]
2020-07-15 13:34:48 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834488,0.00,0]}[flow1]
2020-07-15 13:34:50 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":1993,"rssi":-28,"timestamp":1594834489,"reset_flags":"PIN,SFT","seq":197,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:34:51 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834491,0.00,0]}[flow1]
2020-07-15 13:34:52 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834491,0.00,0]}[flow1]
2020-07-15 13:34:54 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834494,0.00,0]}[flow1]
2020-07-15 13:34:55 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834494,0.00,0]}[flow1]
2020-07-15 13:34:57 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834497,0.00,0]}[flow1]
2020-07-15 13:34:58 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834497,0.00,0]}[flow1]
2020-07-15 13:35:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2003,"rssi":-26,"timestamp":1594834499,"reset_flags":"PIN,SFT","seq":198,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:35:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834500,0.00,0]}[flow1]
2020-07-15 13:35:01 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834500,0.00,0]}[flow1]
2020-07-15 13:35:03 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834503,0.00,0]}[flow1]
2020-07-15 13:35:04 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834503,0.00,0]}[flow1]
2020-07-15 13:35:06 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834506,0.00,0]}[flow1]
2020-07-15 13:35:07 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834506,0.00,0]}[flow1]
2020-07-15 13:35:09 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834509,0.00,0]}[flow1]
2020-07-15 13:35:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834509,0.00,0]}[flow1]
2020-07-15 13:35:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2013,"rssi":-26,"timestamp":1594834509,"reset_flags":"PIN,SFT","seq":199,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:35:13 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834512,0.00,0]}[flow1]
2020-07-15 13:35:16 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834515,0.00,0]}[flow1]
2020-07-15 13:35:18 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834518,0.00,0]}[flow1]
2020-07-15 13:35:20 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2023,"rssi":-26,"timestamp":1594834519,"reset_flags":"PIN,SFT","seq":200,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:35:21 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834521,0.00,0]}[flow1]
2020-07-15 13:35:22 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834521,0.00,0]}[flow1]
2020-07-15 13:35:24 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834524,0.00,0]}[flow1]
2020-07-15 13:35:25 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834524,0.00,0]}[flow1]
2020-07-15 13:35:28 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834527,0.00,0]}[flow1]
2020-07-15 13:35:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2033,"rssi":-26,"timestamp":1594834529,"reset_flags":"PIN,SFT","seq":201,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:35:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834530,0.00,0]}[flow1]
2020-07-15 13:35:31 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834530,0.00,0]}[flow1]
2020-07-15 13:35:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"device_status","hub_sn":"HB-00010608","timestamp":1594834532,"uptime":77410,"voltage":3.46,"firmware_revision":43,"rssi":-34,"hub_rssi":-34,"sensor_status":0,"debug":0}[flow1]
2020-07-15 13:35:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"obs_sky","hub_sn":"HB-00010608","obs":[[1594834532,131,0.00,0.000000,0.00,0.00,0.00,0,3.461,1,1,null,0,3]],"firmware_revision":43}[flow1]
2020-07-15 13:35:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834533,0.00,0]}[flow1]
2020-07-15 13:35:34 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834533,0.00,0]}[flow1]
2020-07-15 13:35:36 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834536,0.00,0]}[flow1]
2020-07-15 13:35:37 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834536,0.00,0]}[flow1]
2020-07-15 13:35:39 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834539,0.00,0]}[flow1]
2020-07-15 13:35:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834539,0.00,0]}[flow1]
2020-07-15 13:35:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2043,"rssi":-27,"timestamp":1594834539,"reset_flags":"PIN,SFT","seq":202,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:35:43 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834542,0.31,265]}[flow1]
2020-07-15 13:35:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"device_status","hub_sn":"HB-00010608","timestamp":1594834544,"uptime":54904,"voltage":3.50,"firmware_revision":20,"rssi":-22,"hub_rssi":0,"sensor_status":0,"debug":0}[flow1]
2020-07-15 13:35:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"obs_air","hub_sn":"HB-00010608","obs":[[1594834544,986.20,25.40,43,0,0,3.502,1]],"firmware_revision":20}[flow1]
2020-07-15 13:35:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834545,0.00,0]}[flow1]
2020-07-15 13:35:46 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834545,0.00,0]}[flow1]
2020-07-15 13:35:48 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834548,0.00,0]}[flow1]
2020-07-15 13:35:49 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834548,0.00,0]}[flow1]
2020-07-15 13:35:50 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2053,"rssi":-30,"timestamp":1594834549,"reset_flags":"PIN,SFT","seq":203,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:35:51 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834551,0.00,0]}[flow1]
2020-07-15 13:35:52 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834551,0.00,0]}[flow1]
2020-07-15 13:35:54 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834554,0.00,0]}[flow1]
2020-07-15 13:35:55 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834554,0.00,0]}[flow1]
2020-07-15 13:35:57 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834557,0.00,0]}[flow1]
2020-07-15 13:35:58 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834557,0.00,0]}[flow1]
2020-07-15 13:36:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2063,"rssi":-27,"timestamp":1594834559,"reset_flags":"PIN,SFT","seq":204,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:36:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834560,0.00,0]}[flow1]
2020-07-15 13:36:03 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834563,0.00,0]}[flow1]
2020-07-15 13:36:07 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834566,0.00,0]}[flow1]
2020-07-15 13:36:09 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834569,0.00,0]}[flow1]
2020-07-15 13:36:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834569,0.00,0]}[flow1]
2020-07-15 13:36:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2073,"rssi":-27,"timestamp":1594834569,"reset_flags":"PIN,SFT","seq":205,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:36:12 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834572,0.00,0]}[flow1]
2020-07-15 13:36:13 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834572,0.00,0]}[flow1]
2020-07-15 13:36:15 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834575,0.00,0]}[flow1]
2020-07-15 13:36:18 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834578,0.00,0]}[flow1]
2020-07-15 13:36:19 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834578,0.00,0]}[flow1]
2020-07-15 13:36:20 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2083,"rssi":-27,"timestamp":1594834579,"reset_flags":"PIN,SFT","seq":206,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:36:21 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834581,0.00,0]}[flow1]
2020-07-15 13:36:22 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834581,0.00,0]}[flow1]
2020-07-15 13:36:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2093,"rssi":-28,"timestamp":1594834589,"reset_flags":"PIN,SFT","seq":207,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:36:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834590,0.00,0]}[flow1]
2020-07-15 13:36:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"device_status","hub_sn":"HB-00010608","timestamp":1594834592,"uptime":77470,"voltage":3.46,"firmware_revision":43,"rssi":-35,"hub_rssi":-36,"sensor_status":0,"debug":0}[flow1]
2020-07-15 13:36:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"obs_sky","hub_sn":"HB-00010608","obs":[[1594834592,133,0.00,0.000000,0.00,0.02,0.31,265,3.461,1,1,null,0,3]],"firmware_revision":43}[flow1]
2020-07-15 13:36:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834593,0.00,0]}[flow1]
2020-07-15 13:36:36 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834596,0.00,0]}[flow1]
2020-07-15 13:36:37 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834596,0.00,0]}[flow1]
2020-07-15 13:36:39 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834599,0.00,0]}[flow1]
2020-07-15 13:36:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2103,"rssi":-27,"timestamp":1594834599,"reset_flags":"PIN,SFT","seq":208,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:36:42 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834602,0.00,0]}[flow1]
2020-07-15 13:36:43 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834602,0.00,0]}[flow1]
2020-07-15 13:36:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"device_status","hub_sn":"HB-00010608","timestamp":1594834604,"uptime":54964,"voltage":3.50,"firmware_revision":20,"rssi":-18,"hub_rssi":0,"sensor_status":4,"debug":0}[flow1]
2020-07-15 13:36:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"obs_air","hub_sn":"HB-00010608","obs":[[1594834604,986.20,25.42,43,0,0,3.500,1]],"firmware_revision":20}[flow1]
2020-07-15 13:36:47 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834605,0.00,0]}[flow1]
2020-07-15 13:36:48 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834608,0.00,0]}[flow1]
2020-07-15 13:36:49 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834608,0.00,0]}[flow1]
2020-07-15 13:36:50 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2113,"rssi":-27,"timestamp":1594834609,"reset_flags":"PIN,SFT","seq":209,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:36:51 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834611,0.00,0]}[flow1]
2020-07-15 13:36:54 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834614,0.00,0]}[flow1]
2020-07-15 13:36:55 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834614,0.00,0]}[flow1]
2020-07-15 13:36:57 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834617,0.00,0]}[flow1]
2020-07-15 13:37:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2123,"rssi":-27,"timestamp":1594834619,"reset_flags":"PIN,SFT","seq":210,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[1,0]}[flow1]
2020-07-15 13:37:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834620,0.00,0]}[flow1]
2020-07-15 13:37:01 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834620,0.00,0]}[flow1]
2020-07-15 13:37:03 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834623,0.00,0]}[flow1]
2020-07-15 13:37:04 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834623,0.00,0]}[flow1]
2020-07-15 13:37:06 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834626,0.00,0]}[flow1]
2020-07-15 13:37:09 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834629,0.00,0]}[flow1]
2020-07-15 13:37:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834629,0.00,0]}[flow1]
2020-07-15 13:37:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2133,"rssi":-25,"timestamp":1594834629,"reset_flags":"PIN,SFT","seq":211,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:37:12 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834632,0.00,0]}[flow1]
2020-07-15 13:37:15 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834635,0.00,0]}[flow1]
2020-07-15 13:37:16 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834635,0.00,0]}[flow1]
2020-07-15 13:37:18 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834638,0.00,0]}[flow1]
2020-07-15 13:37:20 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2143,"rssi":-27,"timestamp":1594834639,"reset_flags":"PIN,SFT","seq":212,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:37:21 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"obs_air","hub_sn":"HB-00010608","obs":[[1594834604,986.20,25.42,43,0,0,3.500,1]],"firmware_revision":20}[flow1]
2020-07-15 13:37:21 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834641,0.00,0]}[flow1]
2020-07-15 13:37:24 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834644,0.00,0]}[flow1]
2020-07-15 13:37:27 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834647,0.00,0]}[flow1]
2020-07-15 13:37:28 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834647,0.00,0]}[flow1]
2020-07-15 13:37:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2153,"rssi":-27,"timestamp":1594834649,"reset_flags":"PIN,SFT","seq":213,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:37:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834650,0.00,0]}[flow1]
2020-07-15 13:37:31 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834650,0.00,0]}[flow1]
2020-07-15 13:37:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"device_status","hub_sn":"HB-00010608","timestamp":1594834652,"uptime":77530,"voltage":3.45,"firmware_revision":43,"rssi":-34,"hub_rssi":-35,"sensor_status":0,"debug":0}[flow1]
2020-07-15 13:37:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"obs_sky","hub_sn":"HB-00010608","obs":[[1594834652,137,0.00,0.000000,0.00,0.00,0.00,0,3.452,1,1,null,0,3]],"firmware_revision":43}[flow1]
2020-07-15 13:37:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834653,0.00,0]}[flow1]
2020-07-15 13:37:36 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834656,0.00,0]}[flow1]
2020-07-15 13:37:37 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834656,0.00,0]}[flow1]
2020-07-15 13:37:39 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834659,0.00,0]}[flow1]
2020-07-15 13:37:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834659,0.00,0]}[flow1]
2020-07-15 13:37:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2163,"rssi":-26,"timestamp":1594834659,"reset_flags":"PIN,SFT","seq":214,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:37:42 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834662,0.00,0]}[flow1]
2020-07-15 13:37:43 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834662,0.00,0]}[flow1]
2020-07-15 13:37:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"device_status","hub_sn":"HB-00010608","timestamp":1594834664,"uptime":55024,"voltage":3.50,"firmware_revision":20,"rssi":-18,"hub_rssi":0,"sensor_status":4,"debug":0}[flow1]
2020-07-15 13:37:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"obs_air","hub_sn":"HB-00010608","obs":[[1594834664,986.20,25.44,43,0,0,3.502,1]],"firmware_revision":20}[flow1]
2020-07-15 13:37:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834665,0.00,0]}[flow1]
2020-07-15 13:37:46 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834665,0.00,0]}[flow1]
2020-07-15 13:37:48 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834668,0.00,0]}[flow1]
2020-07-15 13:37:50 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2173,"rssi":-27,"timestamp":1594834669,"reset_flags":"PIN,SFT","seq":215,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:37:51 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834671,0.00,0]}[flow1]
2020-07-15 13:37:54 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834674,0.00,0]}[flow1]
2020-07-15 13:37:55 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834674,0.00,0]}[flow1]
2020-07-15 13:37:57 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834677,0.00,0]}[flow1]
2020-07-15 13:38:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2183,"rssi":-27,"timestamp":1594834679,"reset_flags":"PIN,SFT","seq":216,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:38:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834680,0.00,0]}[flow1]
2020-07-15 13:38:03 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834683,0.00,0]}[flow1]
2020-07-15 13:38:06 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834686,0.00,0]}[flow1]
2020-07-15 13:38:07 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834686,0.00,0]}[flow1]
2020-07-15 13:38:09 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834689,0.00,0]}[flow1]
2020-07-15 13:38:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2193,"rssi":-25,"timestamp":1594834689,"reset_flags":"PIN,SFT","seq":217,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:38:12 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834692,0.00,0]}[flow1]
2020-07-15 13:38:15 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834695,0.00,0]}[flow1]
2020-07-15 13:38:18 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834698,0.00,0]}[flow1]
2020-07-15 13:38:19 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834698,0.00,0]}[flow1]
2020-07-15 13:38:20 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2203,"rssi":-26,"timestamp":1594834699,"reset_flags":"PIN,SFT","seq":218,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:38:21 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834701,0.00,0]}[flow1]
2020-07-15 13:38:22 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834701,0.00,0]}[flow1]
2020-07-15 13:38:24 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834704,0.00,0]}[flow1]
2020-07-15 13:38:27 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834707,0.00,0]}[flow1]
2020-07-15 13:38:28 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834707,0.00,0]}[flow1]
2020-07-15 13:38:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2213,"rssi":-28,"timestamp":1594834709,"reset_flags":"PIN,SFT","seq":219,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:38:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834710,0.00,0]}[flow1]
2020-07-15 13:38:31 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834710,0.00,0]}[flow1]
2020-07-15 13:38:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"device_status","hub_sn":"HB-00010608","timestamp":1594834712,"uptime":77590,"voltage":3.45,"firmware_revision":43,"rssi":-30,"hub_rssi":-32,"sensor_status":0,"debug":0}[flow1]
2020-07-15 13:38:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"obs_sky","hub_sn":"HB-00010608","obs":[[1594834712,130,0.00,0.000000,0.00,0.00,0.00,0,3.452,1,1,null,0,3]],"firmware_revision":43}[flow1]
2020-07-15 13:38:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834713,0.00,0]}[flow1]
2020-07-15 13:38:34 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834713,0.00,0]}[flow1]
2020-07-15 13:38:36 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834716,0.00,0]}[flow1]
2020-07-15 13:38:39 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834719,0.00,0]}[flow1]
2020-07-15 13:38:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2223,"rssi":-27,"timestamp":1594834719,"reset_flags":"PIN,SFT","seq":220,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:38:42 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834722,0.00,0]}[flow1]
2020-07-15 13:38:43 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834722,0.00,0]}[flow1]
2020-07-15 13:38:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"device_status","hub_sn":"HB-00010608","timestamp":1594834724,"uptime":55084,"voltage":3.50,"firmware_revision":20,"rssi":-26,"hub_rssi":0,"sensor_status":4,"debug":0}[flow1]
2020-07-15 13:38:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"obs_air","hub_sn":"HB-00010608","obs":[[1594834724,986.20,25.45,44,0,0,3.502,1]],"firmware_revision":20}[flow1]
2020-07-15 13:38:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834725,0.00,0]}[flow1]
2020-07-15 13:38:46 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834725,0.00,0]}[flow1]
2020-07-15 13:38:48 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834728,0.00,0]}[flow1]
2020-07-15 13:38:50 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2233,"rssi":-27,"timestamp":1594834729,"reset_flags":"PIN,SFT","seq":221,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:38:51 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834731,0.00,0]}[flow1]
2020-07-15 13:38:52 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834731,0.00,0]}[flow1]
2020-07-15 13:38:54 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834734,0.00,0]}[flow1]
2020-07-15 13:38:57 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834737,0.00,0]}[flow1]
2020-07-15 13:38:58 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834737,0.00,0]}[flow1]
2020-07-15 13:39:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2243,"rssi":-26,"timestamp":1594834739,"reset_flags":"PIN,SFT","seq":222,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:39:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834739,0.00,0]}[flow1]
2020-07-15 13:39:03 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834743,0.00,0]}[flow1]
2020-07-15 13:39:04 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834743,0.00,0]}[flow1]
2020-07-15 13:39:06 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834745,0.00,0]}[flow1]
2020-07-15 13:39:09 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834749,0.00,0]}[flow1]
2020-07-15 13:39:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834749,0.00,0]}[flow1]
2020-07-15 13:39:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2253,"rssi":-27,"timestamp":1594834749,"reset_flags":"PIN,SFT","seq":223,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:39:15 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834755,0.00,0]}[flow1]
2020-07-15 13:39:20 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2263,"rssi":-27,"timestamp":1594834759,"reset_flags":"PIN,SFT","seq":224,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:39:21 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834761,0.00,0]}[flow1]
2020-07-15 13:39:22 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834761,0.00,0]}[flow1]
2020-07-15 13:39:24 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834764,0.00,0]}[flow1]
2020-07-15 13:39:25 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834764,0.00,0]}[flow1]
2020-07-15 13:39:28 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834767,0.31,265]}[flow1]
2020-07-15 13:39:31 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834770,0.27,270]}[flow1]
2020-07-15 13:39:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"device_status","hub_sn":"HB-00010608","timestamp":1594834772,"uptime":77650,"voltage":3.45,"firmware_revision":43,"rssi":-30,"hub_rssi":-30,"sensor_status":0,"debug":0}[flow1]
2020-07-15 13:39:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"obs_sky","hub_sn":"HB-00010608","obs":[[1594834772,131,0.00,0.000000,0.00,0.03,0.31,267,3.452,1,1,null,0,3]],"firmware_revision":43}[flow1]
2020-07-15 13:39:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834773,0.00,0]}[flow1]
2020-07-15 13:39:37 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834776,0.27,263]}[flow1]
2020-07-15 13:39:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834779,0.31,304]}[flow1]
2020-07-15 13:39:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2283,"rssi":-26,"timestamp":1594834779,"reset_flags":"PIN,SFT","seq":226,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:39:42 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834782,0.00,0]}[flow1]
2020-07-15 13:39:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"device_status","hub_sn":"HB-00010608","timestamp":1594834784,"uptime":55144,"voltage":3.50,"firmware_revision":20,"rssi":-28,"hub_rssi":0,"sensor_status":0,"debug":0}[flow1]
2020-07-15 13:39:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"obs_air","hub_sn":"HB-00010608","obs":[[1594834784,986.20,25.43,44,0,0,3.500,1]],"firmware_revision":20}[flow1]
2020-07-15 13:39:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834784,0.00,0]}[flow1]
2020-07-15 13:39:48 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834788,0.00,0]}[flow1]
2020-07-15 13:39:49 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834788,0.00,0]}[flow1]
2020-07-15 13:39:50 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2293,"rssi":-26,"timestamp":1594834789,"reset_flags":"PIN,SFT","seq":227,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:39:51 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834790,0.00,0]}[flow1]
2020-07-15 13:39:54 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834794,0.00,0]}[flow1]
2020-07-15 13:39:57 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834796,0.00,0]}[flow1]
2020-07-15 13:40:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2303,"rssi":-26,"timestamp":1594834799,"reset_flags":"PIN,SFT","seq":228,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:40:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834800,0.00,0]}[flow1]
2020-07-15 13:40:01 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834800,0.00,0]}[flow1]
2020-07-15 13:40:03 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834803,0.00,0]}[flow1]
2020-07-15 13:40:06 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834806,0.00,0]}[flow1]
2020-07-15 13:40:09 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834809,0.00,0]}[flow1]
2020-07-15 13:40:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2313,"rssi":-26,"timestamp":1594834809,"reset_flags":"PIN,SFT","seq":229,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:40:12 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834811,0.00,0]}[flow1]
2020-07-15 13:40:13 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834811,0.00,0]}[flow1]
2020-07-15 13:40:15 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834815,0.00,0]}[flow1]
2020-07-15 13:40:16 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834815,0.00,0]}[flow1]
2020-07-15 13:40:18 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834817,0.00,0]}[flow1]
2020-07-15 13:40:20 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2323,"rssi":-25,"timestamp":1594834819,"reset_flags":"PIN,SFT","seq":230,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:40:21 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834821,0.00,0]}[flow1]
2020-07-15 13:40:22 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834821,0.00,0]}[flow1]
2020-07-15 13:40:24 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834823,0.00,0]}[flow1]
2020-07-15 13:40:27 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834827,0.00,0]}[flow1]
2020-07-15 13:40:28 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834827,0.00,0]}[flow1]
2020-07-15 13:40:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2333,"rssi":-25,"timestamp":1594834829,"reset_flags":"PIN,SFT","seq":231,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:40:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834829,0.00,0]}[flow1]
2020-07-15 13:40:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"device_status","hub_sn":"HB-00010608","timestamp":1594834832,"uptime":77710,"voltage":3.45,"firmware_revision":43,"rssi":-27,"hub_rssi":-28,"sensor_status":0,"debug":0}[flow1]
2020-07-15 13:40:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834833,0.00,0]}[flow1]
2020-07-15 13:40:36 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834835,0.00,0]}[flow1]
2020-07-15 13:40:39 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834839,0.00,0]}[flow1]
2020-07-15 13:40:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834839,0.00,0]}[flow1]
2020-07-15 13:40:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2343,"rssi":-27,"timestamp":1594834839,"reset_flags":"PIN,SFT","seq":232,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:40:42 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834841,0.00,0]}[flow1]
2020-07-15 13:40:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"device_status","hub_sn":"HB-00010608","timestamp":1594834844,"uptime":55204,"voltage":3.50,"firmware_revision":20,"rssi":-32,"hub_rssi":0,"sensor_status":4,"debug":0}[flow1]
2020-07-15 13:40:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"obs_air","hub_sn":"HB-00010608","obs":[[1594834844,986.20,25.35,43,0,0,3.500,1]],"firmware_revision":20}[flow1]
2020-07-15 13:40:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834845,0.00,0]}[flow1]
2020-07-15 13:40:48 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834847,0.00,0]}[flow1]
2020-07-15 13:40:50 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2353,"rssi":-28,"timestamp":1594834849,"reset_flags":"PIN,SFT","seq":233,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:40:51 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834851,0.00,0]}[flow1]
2020-07-15 13:40:52 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834851,0.00,0]}[flow1]
2020-07-15 13:40:54 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834854,0.00,0]}[flow1]
2020-07-15 13:40:55 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834854,0.00,0]}[flow1]
2020-07-15 13:40:57 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834856,0.00,0]}[flow1]
2020-07-15 13:41:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2363,"rssi":-27,"timestamp":1594834859,"reset_flags":"PIN,SFT","seq":234,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:41:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834860,0.00,0]}[flow1]
2020-07-15 13:41:03 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834862,0.00,0]}[flow1]
2020-07-15 13:41:07 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834866,0.00,0]}[flow1]
2020-07-15 13:41:09 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834868,0.00,0]}[flow1]
2020-07-15 13:41:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2373,"rssi":-26,"timestamp":1594834869,"reset_flags":"PIN,SFT","seq":235,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:41:12 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834872,0.00,0]}[flow1]
2020-07-15 13:41:15 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834874,0.00,0]}[flow1]
2020-07-15 13:41:18 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834878,0.00,0]}[flow1]
2020-07-15 13:41:19 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834878,0.00,0]}[flow1]
2020-07-15 13:41:20 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2383,"rssi":-26,"timestamp":1594834879,"reset_flags":"PIN,SFT","seq":236,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:41:21 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834880,0.00,0]}[flow1]
2020-07-15 13:41:24 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834883,0.00,0]}[flow1]
2020-07-15 13:41:28 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834887,0.00,0]}[flow1]
2020-07-15 13:41:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2393,"rssi":-26,"timestamp":1594834889,"reset_flags":"PIN,SFT","seq":237,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:41:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834889,0.00,0]}[flow1]
2020-07-15 13:41:31 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834889,0.00,0]}[flow1]
2020-07-15 13:41:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"device_status","hub_sn":"HB-00010608","timestamp":1594834892,"uptime":77770,"voltage":3.45,"firmware_revision":43,"rssi":-27,"hub_rssi":-28,"sensor_status":0,"debug":0}[flow1]
2020-07-15 13:41:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"obs_sky","hub_sn":"HB-00010608","obs":[[1594834892,155,0.00,0.000000,0.00,0.00,0.00,0,3.452,1,1,null,0,3]],"firmware_revision":43}[flow1]
2020-07-15 13:41:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834892,0.00,0]}[flow1]
2020-07-15 13:41:39 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834899,0.00,0]}[flow1]
2020-07-15 13:41:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2403,"rssi":-28,"timestamp":1594834899,"reset_flags":"PIN,SFT","seq":238,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:41:42 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834901,0.00,0]}[flow1]
2020-07-15 13:41:43 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834901,0.00,0]}[flow1]
2020-07-15 13:41:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"device_status","hub_sn":"HB-00010608","timestamp":1594834904,"uptime":55264,"voltage":3.50,"firmware_revision":20,"rssi":-31,"hub_rssi":0,"sensor_status":4,"debug":0}[flow1]
2020-07-15 13:41:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"obs_air","hub_sn":"HB-00010608","obs":[[1594834904,986.30,25.35,43,0,0,3.500,1]],"firmware_revision":20}[flow1]
2020-07-15 13:41:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834905,0.00,0]}[flow1]
2020-07-15 13:41:46 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834905,0.00,0]}[flow1]
2020-07-15 13:41:48 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834907,0.00,0]}[flow1]
2020-07-15 13:41:50 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2413,"rssi":-27,"timestamp":1594834909,"reset_flags":"PIN,SFT","seq":239,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:41:51 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834911,0.00,0]}[flow1]
2020-07-15 13:41:54 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834913,0.00,0]}[flow1]
2020-07-15 13:41:55 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834913,0.00,0]}[flow1]
2020-07-15 13:41:57 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834917,0.00,0]}[flow1]
2020-07-15 13:41:58 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834917,0.00,0]}[flow1]
2020-07-15 13:42:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2423,"rssi":-28,"timestamp":1594834919,"reset_flags":"PIN,SFT","seq":240,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:42:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834919,0.00,0]}[flow1]
2020-07-15 13:42:03 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834922,0.00,0]}[flow1]
2020-07-15 13:42:06 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834925,0.00,0]}[flow1]
2020-07-15 13:42:09 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834928,0.00,0]}[flow1]
2020-07-15 13:42:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834928,0.00,0]}[flow1]
2020-07-15 13:42:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2433,"rssi":-28,"timestamp":1594834929,"reset_flags":"PIN,SFT","seq":241,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:42:12 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834932,0.00,0]}[flow1]
2020-07-15 13:42:13 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834932,0.00,0]}[flow1]
2020-07-15 13:42:15 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834934,0.00,0]}[flow1]
2020-07-15 13:42:18 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834938,0.00,0]}[flow1]
2020-07-15 13:42:20 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2443,"rssi":-27,"timestamp":1594834939,"reset_flags":"PIN,SFT","seq":242,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:42:21 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834940,0.00,0]}[flow1]
2020-07-15 13:42:22 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834940,0.00,0]}[flow1]
2020-07-15 13:42:24 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834944,0.00,0]}[flow1]
2020-07-15 13:42:25 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834944,0.00,0]}[flow1]
2020-07-15 13:42:27 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834946,0.00,0]}[flow1]
2020-07-15 13:42:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2453,"rssi":-27,"timestamp":1594834949,"reset_flags":"PIN,SFT","seq":243,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:42:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834949,0.00,0]}[flow1]
2020-07-15 13:42:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"device_status","hub_sn":"HB-00010608","timestamp":1594834952,"uptime":77830,"voltage":3.45,"firmware_revision":43,"rssi":-28,"hub_rssi":-28,"sensor_status":0,"debug":0}[flow1]
2020-07-15 13:42:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"obs_sky","hub_sn":"HB-00010608","obs":[[1594834952,164,0.00,0.000000,0.00,0.00,0.00,0,3.452,1,1,null,0,3]],"firmware_revision":43}[flow1]
2020-07-15 13:42:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834952,0.00,0]}[flow1]
2020-07-15 13:42:34 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834952,0.00,0]}[flow1]
2020-07-15 13:42:36 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834956,0.00,0]}[flow1]
2020-07-15 13:42:37 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834956,0.00,0]}[flow1]
2020-07-15 13:42:39 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834958,0.00,0]}[flow1]
2020-07-15 13:42:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2463,"rssi":-27,"timestamp":1594834959,"reset_flags":"PIN,SFT","seq":244,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:42:42 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834961,0.00,0]}[flow1]
2020-07-15 13:42:43 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834961,0.00,0]}[flow1]
2020-07-15 13:42:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"device_status","hub_sn":"HB-00010608","timestamp":1594834964,"uptime":55324,"voltage":3.50,"firmware_revision":20,"rssi":-29,"hub_rssi":0,"sensor_status":4,"debug":0}[flow1]
2020-07-15 13:42:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"obs_air","hub_sn":"HB-00010608","obs":[[1594834964,986.30,25.28,43,0,0,3.502,1]],"firmware_revision":20}[flow1]
2020-07-15 13:42:46 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834964,0.00,0]}[flow1]
2020-07-15 13:42:48 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834967,0.00,0]}[flow1]
2020-07-15 13:42:49 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834967,0.00,0]}[flow1]
2020-07-15 13:42:50 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2473,"rssi":-27,"timestamp":1594834969,"reset_flags":"PIN,SFT","seq":245,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:42:54 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834973,0.00,0]}[flow1]
2020-07-15 13:42:55 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834973,0.00,0]}[flow1]
2020-07-15 13:42:57 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834976,0.00,0]}[flow1]
2020-07-15 13:43:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2483,"rssi":-27,"timestamp":1594834979,"reset_flags":"PIN,SFT","seq":246,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:43:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834979,0.00,0]}[flow1]
2020-07-15 13:43:01 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834979,0.00,0]}[flow1]
2020-07-15 13:43:03 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834982,0.00,0]}[flow1]
2020-07-15 13:43:06 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834986,0.00,0]}[flow1]
2020-07-15 13:43:09 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834988,0.00,0]}[flow1]
2020-07-15 13:43:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834988,0.00,0]}[flow1]
2020-07-15 13:43:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2493,"rssi":-27,"timestamp":1594834989,"reset_flags":"PIN,SFT","seq":247,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:43:12 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834991,0.00,0]}[flow1]
2020-07-15 13:43:13 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834991,0.00,0]}[flow1]
2020-07-15 13:43:15 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834994,0.00,0]}[flow1]
2020-07-15 13:43:18 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594834997,0.00,0]}[flow1]
2020-07-15 13:43:20 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2503,"rssi":-26,"timestamp":1594834999,"reset_flags":"PIN,SFT","seq":248,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:43:21 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835000,0.00,0]}[flow1]
2020-07-15 13:43:24 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835003,0.00,0]}[flow1]
2020-07-15 13:43:25 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835003,0.00,0]}[flow1]
2020-07-15 13:43:27 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835006,0.00,0]}[flow1]
2020-07-15 13:43:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2513,"rssi":-27,"timestamp":1594835009,"reset_flags":"PIN,SFT","seq":249,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:43:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835009,0.00,0]}[flow1]
2020-07-15 13:43:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"device_status","hub_sn":"HB-00010608","timestamp":1594835012,"uptime":77890,"voltage":3.45,"firmware_revision":43,"rssi":-27,"hub_rssi":-28,"sensor_status":0,"debug":0}[flow1]
2020-07-15 13:43:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"obs_sky","hub_sn":"HB-00010608","obs":[[1594835012,162,0.00,0.000000,0.00,0.00,0.00,0,3.452,1,1,null,0,3]],"firmware_revision":43}[flow1]
2020-07-15 13:43:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835012,0.00,0]}[flow1]
2020-07-15 13:43:36 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835015,0.00,0]}[flow1]
2020-07-15 13:43:37 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835015,0.00,0]}[flow1]
2020-07-15 13:43:39 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835018,0.00,0]}[flow1]
2020-07-15 13:43:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2523,"rssi":-27,"timestamp":1594835019,"reset_flags":"PIN,SFT","seq":250,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:43:42 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835021,0.00,0]}[flow1]
2020-07-15 13:43:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"device_status","hub_sn":"HB-00010608","timestamp":1594835024,"uptime":55384,"voltage":3.50,"firmware_revision":20,"rssi":-30,"hub_rssi":0,"sensor_status":0,"debug":0}[flow1]
2020-07-15 13:43:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835024,0.00,0]}[flow1]
2020-07-15 13:43:48 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835027,0.00,0]}[flow1]
2020-07-15 13:43:49 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835027,0.00,0]}[flow1]
2020-07-15 13:43:50 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2533,"rssi":-27,"timestamp":1594835029,"reset_flags":"PIN,SFT","seq":251,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:43:51 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835031,0.00,0]}[flow1]
2020-07-15 13:43:52 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835031,0.00,0]}[flow1]
2020-07-15 13:43:54 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835033,0.00,0]}[flow1]
2020-07-15 13:43:57 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835036,0.00,0]}[flow1]
2020-07-15 13:44:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2543,"rssi":-28,"timestamp":1594835039,"reset_flags":"PIN,SFT","seq":252,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:44:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835039,0.00,0]}[flow1]
2020-07-15 13:44:03 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835042,0.00,0]}[flow1]
2020-07-15 13:44:06 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835045,0.00,0]}[flow1]
2020-07-15 13:44:09 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835048,0.00,0]}[flow1]
2020-07-15 13:44:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2553,"rssi":-25,"timestamp":1594835049,"reset_flags":"PIN,SFT","seq":253,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:44:12 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835051,0.00,0]}[flow1]
2020-07-15 13:44:15 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835054,0.00,0]}[flow1]
2020-07-15 13:44:16 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835054,0.00,0]}[flow1]
2020-07-15 13:44:18 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835057,0.00,0]}[flow1]
2020-07-15 13:44:20 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2563,"rssi":-27,"timestamp":1594835059,"reset_flags":"PIN,SFT","seq":254,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:44:21 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835060,0.00,0]}[flow1]
2020-07-15 13:44:24 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835063,0.00,0]}[flow1]
2020-07-15 13:44:27 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835066,0.00,0]}[flow1]
2020-07-15 13:44:28 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835066,0.00,0]}[flow1]
2020-07-15 13:44:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2573,"rssi":-27,"timestamp":1594835069,"reset_flags":"PIN,SFT","seq":255,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:44:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835069,0.00,0]}[flow1]
2020-07-15 13:44:31 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835069,0.00,0]}[flow1]
2020-07-15 13:44:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"device_status","hub_sn":"HB-00010608","timestamp":1594835072,"uptime":77950,"voltage":3.45,"firmware_revision":43,"rssi":-29,"hub_rssi":-30,"sensor_status":0,"debug":0}[flow1]
2020-07-15 13:44:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"obs_sky","hub_sn":"HB-00010608","obs":[[1594835072,171,0.00,0.000000,0.00,0.00,0.00,0,3.452,1,1,null,0,3]],"firmware_revision":43}[flow1]
2020-07-15 13:44:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835072,0.00,0]}[flow1]
2020-07-15 13:44:36 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835075,0.00,0]}[flow1]
2020-07-15 13:44:39 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835078,0.00,0]}[flow1]
2020-07-15 13:44:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2583,"rssi":-28,"timestamp":1594835079,"reset_flags":"PIN,SFT","seq":256,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:44:42 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835081,0.00,0]}[flow1]
2020-07-15 13:44:43 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835081,0.00,0]}[flow1]
2020-07-15 13:44:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"device_status","hub_sn":"HB-00010608","timestamp":1594835084,"uptime":55444,"voltage":3.50,"firmware_revision":20,"rssi":-28,"hub_rssi":0,"sensor_status":4,"debug":0}[flow1]
2020-07-15 13:44:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"obs_air","hub_sn":"HB-00010608","obs":[[1594835084,986.30,25.19,43,0,0,3.502,1]],"firmware_revision":20}[flow1]
2020-07-15 13:44:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835084,0.00,0]}[flow1]
2020-07-15 13:44:48 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835087,0.00,0]}[flow1]
2020-07-15 13:44:50 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2593,"rssi":-26,"timestamp":1594835089,"reset_flags":"PIN,SFT","seq":257,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:44:51 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835090,0.00,0]}[flow1]
2020-07-15 13:44:54 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835093,0.00,0]}[flow1]
2020-07-15 13:44:55 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835093,0.00,0]}[flow1]
2020-07-15 13:44:57 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835096,0.00,0]}[flow1]
2020-07-15 13:45:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2603,"rssi":-28,"timestamp":1594835099,"reset_flags":"PIN,SFT","seq":258,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:45:04 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835103,0.36,266]}[flow1]
2020-07-15 13:45:06 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835105,0.00,0]}[flow1]
2020-07-15 13:45:07 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835105,0.00,0]}[flow1]
2020-07-15 13:45:09 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835108,0.00,0]}[flow1]
2020-07-15 13:45:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2613,"rssi":-28,"timestamp":1594835109,"reset_flags":"PIN,SFT","seq":259,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:45:12 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835111,0.00,0]}[flow1]
2020-07-15 13:45:15 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835114,0.00,0]}[flow1]
2020-07-15 13:45:18 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835117,0.00,0]}[flow1]
2020-07-15 13:45:19 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835117,0.00,0]}[flow1]
2020-07-15 13:45:20 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2623,"rssi":-27,"timestamp":1594835119,"reset_flags":"PIN,SFT","seq":260,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:45:21 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835120,0.00,0]}[flow1]
2020-07-15 13:45:22 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835120,0.00,0]}[flow1]
2020-07-15 13:45:24 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835123,0.00,0]}[flow1]
2020-07-15 13:45:27 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835126,0.00,0]}[flow1]
2020-07-15 13:45:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2633,"rssi":-27,"timestamp":1594835129,"reset_flags":"PIN,SFT","seq":261,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:45:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835129,0.00,0]}[flow1]
2020-07-15 13:45:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"device_status","hub_sn":"HB-00010608","timestamp":1594835132,"uptime":78010,"voltage":3.45,"firmware_revision":43,"rssi":-24,"hub_rssi":-26,"sensor_status":0,"debug":0}[flow1]
2020-07-15 13:45:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"obs_sky","hub_sn":"HB-00010608","obs":[[1594835132,176,0.00,0.000000,0.00,0.02,0.36,266,3.452,1,1,null,0,3]],"firmware_revision":43}[flow1]
2020-07-15 13:45:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835132,0.00,0]}[flow1]
2020-07-15 13:45:34 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835132,0.00,0]}[flow1]
2020-07-15 13:45:36 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835135,0.00,0]}[flow1]
2020-07-15 13:45:39 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835138,0.00,0]}[flow1]
2020-07-15 13:45:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2643,"rssi":-27,"timestamp":1594835139,"reset_flags":"PIN,SFT","seq":262,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:45:42 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835141,0.00,0]}[flow1]
2020-07-15 13:45:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"device_status","hub_sn":"HB-00010608","timestamp":1594835144,"uptime":55504,"voltage":3.50,"firmware_revision":20,"rssi":-28,"hub_rssi":0,"sensor_status":4,"debug":0}[flow1]
2020-07-15 13:45:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"obs_air","hub_sn":"HB-00010608","obs":[[1594835144,986.30,25.21,43,0,0,3.502,1]],"firmware_revision":20}[flow1]
2020-07-15 13:45:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835144,0.00,0]}[flow1]
2020-07-15 13:45:46 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835144,0.00,0]}[flow1]
2020-07-15 13:45:50 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2653,"rssi":-28,"timestamp":1594835149,"reset_flags":"PIN,SFT","seq":263,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:45:51 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835150,0.00,0]}[flow1]
2020-07-15 13:45:55 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835154,0.27,259]}[flow1]
2020-07-15 13:45:57 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835156,0.00,0]}[flow1]
2020-07-15 13:45:58 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835156,0.00,0]}[flow1]
2020-07-15 13:46:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2663,"rssi":-27,"timestamp":1594835159,"reset_flags":"PIN,SFT","seq":264,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:46:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835159,0.00,0]}[flow1]
2020-07-15 13:46:03 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835162,0.00,0]}[flow1]
2020-07-15 13:46:06 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835165,0.00,0]}[flow1]
2020-07-15 13:46:09 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835168,0.00,0]}[flow1]
2020-07-15 13:46:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2673,"rssi":-28,"timestamp":1594835169,"reset_flags":"PIN,SFT","seq":265,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:46:12 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835171,0.00,0]}[flow1]
2020-07-15 13:46:13 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835171,0.00,0]}[flow1]
2020-07-15 13:46:15 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835174,0.00,0]}[flow1]
2020-07-15 13:46:18 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835177,0.00,0]}[flow1]
2020-07-15 13:46:20 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2683,"rssi":-27,"timestamp":1594835179,"reset_flags":"PIN,SFT","seq":266,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:46:21 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835180,0.00,0]}[flow1]
2020-07-15 13:46:24 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835183,0.00,0]}[flow1]
2020-07-15 13:46:25 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835183,0.00,0]}[flow1]
2020-07-15 13:46:27 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835186,0.00,0]}[flow1]
2020-07-15 13:46:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2693,"rssi":-27,"timestamp":1594835189,"reset_flags":"PIN,SFT","seq":267,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:46:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835189,0.00,0]}[flow1]
2020-07-15 13:46:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"device_status","hub_sn":"HB-00010608","timestamp":1594835192,"uptime":78070,"voltage":3.45,"firmware_revision":43,"rssi":-24,"hub_rssi":-26,"sensor_status":0,"debug":0}[flow1]
2020-07-15 13:46:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"obs_sky","hub_sn":"HB-00010608","obs":[[1594835192,178,0.00,0.000000,0.00,0.01,0.27,259,3.452,1,1,null,0,3]],"firmware_revision":43}[flow1]
2020-07-15 13:46:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835192,0.00,0]}[flow1]
2020-07-15 13:46:36 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835195,0.00,0]}[flow1]
2020-07-15 13:46:37 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835195,0.00,0]}[flow1]
2020-07-15 13:46:39 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835198,0.00,0]}[flow1]
2020-07-15 13:46:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2703,"rssi":-27,"timestamp":1594835199,"reset_flags":"PIN,SFT","seq":268,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:46:42 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835201,0.00,0]}[flow1]
2020-07-15 13:46:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"device_status","hub_sn":"HB-00010608","timestamp":1594835204,"uptime":55564,"voltage":3.50,"firmware_revision":20,"rssi":-28,"hub_rssi":0,"sensor_status":0,"debug":0}[flow1]
2020-07-15 13:46:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"obs_air","hub_sn":"HB-00010608","obs":[[1594835204,986.30,25.16,43,0,0,3.502,1]],"firmware_revision":20}[flow1]
2020-07-15 13:46:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835204,0.00,0]}[flow1]
2020-07-15 13:46:48 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835207,0.00,0]}[flow1]
2020-07-15 13:46:50 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2713,"rssi":-27,"timestamp":1594835209,"reset_flags":"PIN,SFT","seq":269,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:46:51 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835210,0.00,0]}[flow1]
2020-07-15 13:46:54 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835213,0.00,0]}[flow1]
2020-07-15 13:46:57 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835216,0.00,0]}[flow1]
2020-07-15 13:47:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2723,"rssi":-27,"timestamp":1594835219,"reset_flags":"PIN,SFT","seq":270,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:47:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835219,0.00,0]}[flow1]
2020-07-15 13:47:03 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835222,0.00,0]}[flow1]
2020-07-15 13:47:04 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835222,0.00,0]}[flow1]
2020-07-15 13:47:06 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835225,0.00,0]}[flow1]
2020-07-15 13:47:09 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835228,0.00,0]}[flow1]
2020-07-15 13:47:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2733,"rssi":-26,"timestamp":1594835229,"reset_flags":"PIN,SFT","seq":271,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:47:12 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835231,0.00,0]}[flow1]
2020-07-15 13:47:15 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835234,0.00,0]}[flow1]
2020-07-15 13:47:16 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835234,0.00,0]}[flow1]
2020-07-15 13:47:18 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835237,0.00,0]}[flow1]
2020-07-15 13:47:20 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2743,"rssi":-26,"timestamp":1594835239,"reset_flags":"PIN,SFT","seq":272,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:47:21 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835240,0.00,0]}[flow1]
2020-07-15 13:47:24 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835243,0.00,0]}[flow1]
2020-07-15 13:47:27 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835246,0.00,0]}[flow1]
2020-07-15 13:47:28 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835246,0.00,0]}[flow1]
2020-07-15 13:47:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2753,"rssi":-26,"timestamp":1594835249,"reset_flags":"PIN,SFT","seq":273,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:47:31 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835249,0.00,0]}[flow1]
2020-07-15 13:47:32 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835249,0.00,0]}[flow1]
2020-07-15 13:47:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"device_status","hub_sn":"HB-00010608","timestamp":1594835252,"uptime":78130,"voltage":3.46,"firmware_revision":43,"rssi":-27,"hub_rssi":-28,"sensor_status":0,"debug":0}[flow1]
2020-07-15 13:47:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"obs_sky","hub_sn":"HB-00010608","obs":[[1594835252,177,0.00,0.000000,0.00,0.00,0.00,0,3.459,1,1,null,0,3]],"firmware_revision":43}[flow1]
2020-07-15 13:47:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835252,0.00,0]}[flow1]
2020-07-15 13:47:36 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835255,0.00,0]}[flow1]
2020-07-15 13:47:39 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835258,0.00,0]}[flow1]
2020-07-15 13:47:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2763,"rssi":-27,"timestamp":1594835259,"reset_flags":"PIN,SFT","seq":274,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:47:42 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835261,0.00,0]}[flow1]
2020-07-15 13:47:43 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835261,0.00,0]}[flow1]
2020-07-15 13:47:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"device_status","hub_sn":"HB-00010608","timestamp":1594835264,"uptime":55624,"voltage":3.50,"firmware_revision":20,"rssi":-32,"hub_rssi":0,"sensor_status":4,"debug":0}[flow1]
2020-07-15 13:47:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"obs_air","hub_sn":"HB-00010608","obs":[[1594835264,986.30,25.11,43,0,0,3.500,1]],"firmware_revision":20}[flow1]
2020-07-15 13:47:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835264,0.00,0]}[flow1]
2020-07-15 13:47:48 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835267,0.00,0]}[flow1]
2020-07-15 13:47:50 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2773,"rssi":-26,"timestamp":1594835269,"reset_flags":"PIN,SFT","seq":275,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:47:51 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835270,0.00,0]}[flow1]
2020-07-15 13:47:54 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835273,0.00,0]}[flow1]
2020-07-15 13:47:55 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835273,0.00,0]}[flow1]
2020-07-15 13:47:57 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835276,0.00,0]}[flow1]
2020-07-15 13:48:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2783,"rssi":-26,"timestamp":1594835279,"reset_flags":"PIN,SFT","seq":276,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:48:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835279,0.00,0]}[flow1]
2020-07-15 13:48:03 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835282,0.00,0]}[flow1]
2020-07-15 13:48:09 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835288,0.00,0]}[flow1]
2020-07-15 13:48:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2793,"rssi":-27,"timestamp":1594835289,"reset_flags":"PIN,SFT","seq":277,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:48:12 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835291,0.00,0]}[flow1]
2020-07-15 13:48:15 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835294,0.00,0]}[flow1]
2020-07-15 13:48:18 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835297,0.00,0]}[flow1]
2020-07-15 13:48:20 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2803,"rssi":-26,"timestamp":1594835299,"reset_flags":"PIN,SFT","seq":278,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:48:21 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835300,0.00,0]}[flow1]
2020-07-15 13:48:22 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835300,0.00,0]}[flow1]
2020-07-15 13:48:24 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835303,0.00,0]}[flow1]
2020-07-15 13:48:27 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835306,0.00,0]}[flow1]
2020-07-15 13:48:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2813,"rssi":-26,"timestamp":1594835309,"reset_flags":"PIN,SFT","seq":279,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:48:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835309,0.00,0]}[flow1]
2020-07-15 13:48:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"device_status","hub_sn":"HB-00010608","timestamp":1594835312,"uptime":78190,"voltage":3.46,"firmware_revision":43,"rssi":-31,"hub_rssi":-32,"sensor_status":0,"debug":0}[flow1]
2020-07-15 13:48:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"obs_sky","hub_sn":"HB-00010608","obs":[[1594835312,179,0.00,0.000000,0.00,0.00,0.00,0,3.459,1,1,null,0,3]],"firmware_revision":43}[flow1]
2020-07-15 13:48:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835312,0.00,0]}[flow1]
2020-07-15 13:48:34 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835312,0.00,0]}[flow1]
2020-07-15 13:48:36 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835315,0.00,0]}[flow1]
2020-07-15 13:48:39 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835318,0.00,0]}[flow1]
2020-07-15 13:48:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2823,"rssi":-27,"timestamp":1594835319,"reset_flags":"PIN,SFT","seq":280,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:48:42 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835321,0.00,0]}[flow1]
2020-07-15 13:48:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"device_status","hub_sn":"HB-00010608","timestamp":1594835324,"uptime":55684,"voltage":3.50,"firmware_revision":20,"rssi":-28,"hub_rssi":0,"sensor_status":4,"debug":0}[flow1]
2020-07-15 13:48:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"obs_air","hub_sn":"HB-00010608","obs":[[1594835324,986.30,25.10,43,0,0,3.502,1]],"firmware_revision":20}[flow1]
2020-07-15 13:48:46 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835324,0.00,0]}[flow1]
2020-07-15 13:48:48 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835327,0.00,0]}[flow1]
2020-07-15 13:48:50 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2833,"rssi":-26,"timestamp":1594835329,"reset_flags":"PIN,SFT","seq":281,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:48:51 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835330,0.00,0]}[flow1]
2020-07-15 13:48:54 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835333,0.00,0]}[flow1]
2020-07-15 13:48:57 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835336,0.00,0]}[flow1]
2020-07-15 13:48:58 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835336,0.00,0]}[flow1]
2020-07-15 13:49:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2843,"rssi":-27,"timestamp":1594835339,"reset_flags":"PIN,SFT","seq":282,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:49:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835339,0.00,0]}[flow1]
2020-07-15 13:49:03 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835342,0.00,0]}[flow1]
2020-07-15 13:49:04 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835342,0.00,0]}[flow1]
2020-07-15 13:49:06 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835345,0.00,0]}[flow1]
2020-07-15 13:49:07 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835345,0.00,0]}[flow1]
2020-07-15 13:49:09 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835348,0.00,0]}[flow1]
2020-07-15 13:49:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2853,"rssi":-27,"timestamp":1594835349,"reset_flags":"PIN,SFT","seq":283,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:49:12 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835351,0.00,0]}[flow1]
2020-07-15 13:49:13 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835351,0.00,0]}[flow1]
2020-07-15 13:49:15 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835354,0.00,0]}[flow1]
2020-07-15 13:49:18 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835357,0.00,0]}[flow1]
2020-07-15 13:49:20 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2863,"rssi":-26,"timestamp":1594835359,"reset_flags":"PIN,SFT","seq":284,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:49:21 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835360,0.00,0]}[flow1]
2020-07-15 13:49:24 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835363,0.00,0]}[flow1]
2020-07-15 13:49:27 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835366,0.00,0]}[flow1]
2020-07-15 13:49:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2873,"rssi":-26,"timestamp":1594835369,"reset_flags":"PIN,SFT","seq":285,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:49:30 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835369,0.00,0]}[flow1]
2020-07-15 13:49:32 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"device_status","hub_sn":"HB-00010608","timestamp":1594835371,"uptime":78250,"voltage":3.46,"firmware_revision":43,"rssi":-32,"hub_rssi":-32,"sensor_status":0,"debug":0}[flow1]
2020-07-15 13:49:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"obs_sky","hub_sn":"HB-00010608","obs":[[1594835371,182,0.00,0.000000,0.00,0.00,0.00,0,3.459,1,1,null,0,3]],"firmware_revision":43}[flow1]
2020-07-15 13:49:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835372,0.00,0]}[flow1]
2020-07-15 13:49:36 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835375,0.00,0]}[flow1]
2020-07-15 13:49:39 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835378,0.00,0]}[flow1]
2020-07-15 13:49:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2883,"rssi":-27,"timestamp":1594835379,"reset_flags":"PIN,SFT","seq":286,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:49:42 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835381,0.00,0]}[flow1]
2020-07-15 13:49:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"device_status","hub_sn":"HB-00010608","timestamp":1594835384,"uptime":55744,"voltage":3.50,"firmware_revision":20,"rssi":-28,"hub_rssi":0,"sensor_status":4,"debug":0}[flow1]
2020-07-15 13:49:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"obs_air","hub_sn":"HB-00010608","obs":[[1594835384,986.30,25.09,43,0,0,3.502,1]],"firmware_revision":20}[flow1]
2020-07-15 13:49:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835384,0.00,0]}[flow1]
2020-07-15 13:49:48 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835387,0.00,0]}[flow1]
2020-07-15 13:49:50 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2893,"rssi":-28,"timestamp":1594835389,"reset_flags":"PIN,SFT","seq":287,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:49:51 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835390,0.00,0]}[flow1]
2020-07-15 13:49:54 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835393,0.00,0]}[flow1]
2020-07-15 13:49:57 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835396,0.00,0]}[flow1]
2020-07-15 13:50:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2903,"rssi":-26,"timestamp":1594835399,"reset_flags":"PIN,SFT","seq":288,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:50:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835399,0.00,0]}[flow1]
2020-07-15 13:50:03 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835402,0.00,0]}[flow1]
2020-07-15 13:50:06 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835405,0.00,0]}[flow1]
2020-07-15 13:50:09 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835408,0.00,0]}[flow1]
2020-07-15 13:50:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2913,"rssi":-27,"timestamp":1594835409,"reset_flags":"PIN,SFT","seq":289,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:50:12 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835411,0.00,0]}[flow1]
2020-07-15 13:50:15 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835414,0.00,0]}[flow1]
2020-07-15 13:50:18 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835417,0.00,0]}[flow1]
2020-07-15 13:50:20 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2923,"rssi":-27,"timestamp":1594835419,"reset_flags":"PIN,SFT","seq":290,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:50:21 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835420,0.00,0]}[flow1]
2020-07-15 13:50:24 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835423,0.00,0]}[flow1]
2020-07-15 13:50:27 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835426,0.00,0]}[flow1]
2020-07-15 13:50:31 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835429,0.00,0]}[flow1]
2020-07-15 13:50:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"device_status","hub_sn":"HB-00010608","timestamp":1594835432,"uptime":78310,"voltage":3.46,"firmware_revision":43,"rssi":-30,"hub_rssi":-32,"sensor_status":0,"debug":0}[flow1]
2020-07-15 13:50:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"obs_sky","hub_sn":"HB-00010608","obs":[[1594835432,182,0.00,0.000000,0.00,0.00,0.00,0,3.459,1,1,null,0,3]],"firmware_revision":43}[flow1]
2020-07-15 13:50:33 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835432,0.00,0]}[flow1]
2020-07-15 13:50:36 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835435,0.00,0]}[flow1]
2020-07-15 13:50:39 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835438,0.00,0]}[flow1]
2020-07-15 13:50:40 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2943,"rssi":-27,"timestamp":1594835439,"reset_flags":"PIN,SFT","seq":292,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:50:42 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835441,0.00,0]}[flow1]
2020-07-15 13:50:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"device_status","hub_sn":"HB-00010608","timestamp":1594835444,"uptime":55804,"voltage":3.50,"firmware_revision":20,"rssi":-28,"hub_rssi":0,"sensor_status":4,"debug":0}[flow1]
2020-07-15 13:50:45 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"obs_air","hub_sn":"HB-00010608","obs":[[1594835444,986.40,25.06,43,0,0,3.500,1]],"firmware_revision":20}[flow1]
2020-07-15 13:50:48 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835447,0.00,0]}[flow1]
2020-07-15 13:50:50 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2953,"rssi":-26,"timestamp":1594835449,"reset_flags":"PIN,SFT","seq":293,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:50:51 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835450,0.00,0]}[flow1]
2020-07-15 13:50:54 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835453,0.00,0]}[flow1]
2020-07-15 13:50:57 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835456,0.00,0]}[flow1]
2020-07-15 13:51:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2963,"rssi":-26,"timestamp":1594835459,"reset_flags":"PIN,SFT","seq":294,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:51:00 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835459,0.00,0]}[flow1]
2020-07-15 13:51:03 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835462,0.00,0]}[flow1]
2020-07-15 13:51:06 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835465,0.00,0]}[flow1]
2020-07-15 13:51:09 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835468,0.00,0]}[flow1]
2020-07-15 13:51:10 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":2973,"rssi":-26,"timestamp":1594835469,"reset_flags":"PIN,SFT","seq":295,"fs":[1,0,15675411,524288],"radio_stats":[5,1,0,3,0],"mqtt_stats":[2,0]}[flow1]
2020-07-15 13:51:12 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1594835471,0.00,0]}[flow1]
The heartbeat changes every time data is received from the device, so it won't be at perfect intervals.
If you enable debug on the system config page as well you'll see what NodeLink sends to the ISY.  You should see the heartbeat send after each data packet is received.
I enabled debug on the system config page and also on the WeatherFlow page. Here is an excerpt of the log file (with these debugs enabled, the log file has a lot of lines... so I haven't included many... if more are needed to better analyze this then I will add more):
2020-07-22 14:04:03 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":268388,"rssi":-32,"timestamp":1595441040,"reset_flags":"BOR,PIN,POR","seq":26681,"fs":[1,0,15675411,524288],"radio_stats":[5,9,106,3,0],"mqtt_stats":[99,8]}[flow1]
2020-07-22 14:04:04 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1595441041,0.00,0]}[flow1]
2020-07-22 14:04:13 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":268398,"rssi":-32,"timestamp":1595441050,"reset_flags":"BOR,PIN,POR","seq":26682,"fs":[1,0,15675411,524288],"radio_stats":[5,9,106,3,0],"mqtt_stats":[99,8]}[flow1]
2020-07-22 14:04:19 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"SK-00012738","type":"rapid_wind","hub_sn":"HB-00010608","ob":[1595441056,0.00,0]}[flow1]
2020-07-22 14:04:22 - ISY Send: Variable dsc1-GV11 added to queue (Val: -1, QS: 1)
2020-07-22 14:04:22 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1/report/status/GV11/-1/25)
2020-07-22 14:04:23 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"HB-00010608","type":"hub_status","firmware_revision":"143","uptime":268408,"rssi":-33,"timestamp":1595441060,"reset_flags":"BOR,PIN,POR","seq":26683,"fs":[1,0,15675411,524288],"radio_stats":[5,9,106,3,0],"mqtt_stats":[99,8]}[flow1]
2020-07-22 14:04:25 - ISY Send: Variable rain1-GV1 added to queue (Val: 1, QS: 1)
2020-07-22 14:04:25 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_rain1/report/status/GV1/1/25)
2020-07-22 14:04:27 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"device_status","hub_sn":"HB-00010608","timestamp":1595441064,"uptime":661626,"voltage":3.49,"firmware_revision":20,"rssi":-77,"hub_rssi":0,"sensor_status":0,"debug":0}[flow1]
2020-07-22 14:04:27 - WeatherFlow: UDP (10.0.2.96:50222) - {"serial_number":"AR-00007638","type":"obs_air","hub_sn":"HB-00010608","obs":[[1595441064,981.50,18.98,94,0,0,3.488,1]],"firmware_revision":20}[flow1]
2020-07-22 14:04:27 - ISY Send: Variable flow1_air07638-ST added to queue (Val: -1, QS: 1)
2020-07-22 14:04:27 - ISY Send: Variable flow1_air07638-GV2 added to queue (Val: 18.98, QS: 2)
2020-07-22 14:04:27 - ISY Send: Variable flow1_air07638-GV6 added to queue (Val: 3.488, QS: 3)
2020-07-22 14:04:27 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_flow1_air07638/report/status/ST/-1/25)
2020-07-22 14:04:27 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_flow1_air07638/report/status/GV2/18.98/4)
2020-07-22 14:04:27 - ISY Send: Variable flow1_air07638-ST added to queue (Val: 1, QS: 2)
2020-07-22 14:04:28 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_flow1_air07638/report/status/GV6/3.488/72)
2020-07-22 14:04:28 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_flow1_air07638/report/status/ST/1/25)
I am trying to understand which lines pertain to the WeatherFlow hearbeats... I think that this next line means that the ISY received a value of "-1" for the Air heartbeat... is that right?
If my understanding is correct, then the ISY is getting the next Air heartbeat change a value of "1", one second later with this line.
On the ISY the heartbeat change, from  1 to -1, then back to 1, is almost instantaneous or a flash on the screen! This means that I can't use the normal heartbeat program to monitor the change! Am I right in thinking that something is not working correctly here?
Yep, you're right.
I'll add a flow timer so that the fastest a heartbeat switches is 30s regardless of incoming data.
