A/V Devices input select help.
Is anyone having success with setting channels to using the isy portal?
When I try the command listed in the wiki, reference below.
"Alexa, set channel to <number> on <device>"
Alexa set channel to 1 on kitchen speakers
The response is kitchen speakers doesn't support that.
Alexa set channel to brick on kitchen speakers
I've tried to set the input name to 1 and you get an error of "Input name must be between 2 and 10 characters."
I've tried to set the input name to 11 and you get an error kitchen speakers doesn't support that.
A/V Virtual Device is a feature available with the upcoming ISY Optimized for Smart Home V3. It allows to create virtual Alexa A/V devices that maps to a combination of ISY state variables, network resources and/or programs.
Configuration tips:
  • Create as many virtual A/V devices as you have physical A/V devices. Example; one for the TV, one for the Home theater, etc.
  • All fields are optional.
  • Under Basic, use either Set Channel To, or Channel Up/Channel Down, not both.
  • Under Volume, you can use Set Volume To, Volume Up/Volume Down, or both. If you use both, use the same State Variable.
  • When entering a State Variable value, you can specify an absolute value, or a delta by entering + or - before the number. This can be especially useful for the Volume Up/Volume Down.
  • When you hover on a field label, you get an example of how to use it.
A/V Devices
  • Turn on|off : "Alexa turn <on|off> <device>"
  • Set channel : "Alexa, set channel to <number> on <device>"
  • Change channel : "Alexa, channel <up|down> on <device>"
  • Set volume : "Alexa, set volume to <number> on <device>"
  • Change volume : "Alexa, volume <up|down> on <device>"
  • Mute : "Alexa, <mute|unmute> on <device>"
  • Playback : "Alexa, <play|pause|stop|fast forward|rewind|next|previous|start over> on <device>"
https://wiki.universal-devices.com/index.php?title=ISY_Portal_Amazon_Echo_Integration_V3#A.2FV_Devices
Thank you for any pointers!
Best Regards,
Todd
You seem to be confusing the "Input Select" with "Set channel to".
If you want to change channels, go to the Basic tab, and set the "Set Channel To" to "State Variable", and choose the state variable that will receive the channel number.
If you want to change the input, use: "Alexas, change input to <input name> on <device>
Benoit
  • Thanks 1
@bmercier thank you kindly for the response!  That is super helpful.  Could you point me to the documentation on the command for input in the wiki?  I don't see any reference to the input in the wiki or the help document in the isy portal.
Is there a location with the updated docs on this?
Best regards,
Todd
Best regards,
Todd
Just added it to the Wiki.
The easiest though is this: For each parameters, there is a tooltip that shows how to use it. For example, in the screen shot you attached, move your mouse over "Input 1". This will tell you how to use it with Alexa.
@bmercier  I think the tool tips might not be working for me as I don't see it when in the isy portal.  Maybe it's currently broken?
  The help button is missing information about it.
Configuration tips:
Configuration tips:
Which browser are you using? It's confirmed to work with Chrome.
The help button only shows tips. The goal is not to talk about all the fields, but only about more tricky details.
Benoit
  • 2 months later...
I try and use the change input command and this is what I've ran into.
Any ideas on how I could get the input selection to work?
I changed the names to eliminate any possible other issues.
When I say "Alexa, change input to brick on dog"
I don't know how to set dog to that setting.
These settings working -
  • Turn on|off : "Alexa turn <on|off> dog"
  • Change volume : "Alexa, volume <up|down> on dog"
  • Mute : "Alexa, <mute|unmute> on dog"
  • 10 months later...
Many times, topics, like this one, just seem to end abruptly.  This one ended 11 months ago.
I think I may have had the same problem with using a Network Resource to change my A/V input.  I can't remember exactly the circumstances; however, what I did for each of my A/V inputs is set them to a Program instead of a Network Resource.  Then, in the Program itself, add exactly 1 line to the Then Action, which is "Resource '<resource name>'".
Example (note: my Resource and my Program just happened to be named the same):
      377.1k
