99i wont recognize Remote link 2440
I have a Remote link 2440 that stopped working and am trying to restore the links to it. When changing a link or trying to restore it the program times out and nothing changes.
So in trying to start fresh I deleted the 2440 from the data base and I use the Link management/Link a remote link/ program but no Inseton address pop up in the address box. I hold the dim and bright as instructed. No link.
I also can link the 2440 to other switches manually without using ISY and it works so i know it is transmitting and communicating. I also reset the 2440 to factory setting by taking out the batteries and holding the bright on reinsertion of the battery.
I have anothe 2440 and it will program by isy when making changes and works fine but also will not show up in the address field when trying to linkk t ti the ISY
I have not unpowered the ISY or PLM
I have a ISY99i, 2.7.0, using a iMAC, and the Java work around.
Any help would be great
The RemoteLinc must be entered manually by address: Link_Management_Menu#Link_a_RemoteLinc
Rand
Ah Thank you! I see it now, I casually looked the other day but missed it. I even read the revision number printed on the sticker but it never registered the other numbers were the address. Always the simple things......
Ray
Still wont program, must be broke other one programmed fine.
