August 11, 20206 yr If I disable automatic writes to my battery powered devices using the enable/disable battery powered device writes button at the top of the ISY console, does it also disable writes to the battery powered Z-Wave devices like a Schlage lock, or does it only disable writes to battery powered Insteon devices? Specifically, I send a parameter change to my Schalge locks twice a day and I want to make sure that the program still works if I disable (unselect) the automatic writes option.
August 12, 20205 yr On 8/10/2020 at 6:47 PM, piconut said: If I disable automatic writes to my battery powered devices using the enable/disable battery powered device writes button at the top of the ISY console, does it also disable writes to the battery powered Z-Wave devices ... You are correct, this only applies to Insteon devices, the button is ignored for Z-Wave. For battery powered devices in Z-Wave that go to sleep (unlike door locks that support beaming), we always write any pending changes to them when they wake up.
August 12, 20205 yr 1 hour ago, Chris Jahn said: You are correct, this only applies to Insteon devices, the button is ignored for Z-Wave. For battery powered devices in Z-Wave that go to sleep (unlike door locks that support beaming), we always write any pending changes to them when they wake up. I have 2 Zooz devices (ZWave) that have the green icon, indicating that a write-to-device is pending, but write-to-device does nothing, as is shown in Event Viewer.
