Options for US 220v appliances?
Hello everyone,,
I have an electric heater in my detached garage that's on its own 20A, 240V outlet. Currently most of my stuff is pretty basic, I just have some echos and TPlink plugs and switches. I saw an insteon relay (2477SA1) that may work, but I was hoping there was something out there that would work over wifi and integrate with Alexa. Is there a better option as I don't want to start down the insteon road for a single device at the moment https://19216801.onl/ https://routerlogin.uno/https://192168ll.link/?
Edited by Rancho
Both the Normally Open and Normally Closed version of that module. Are discontinued from the information on the Insteon web site.
There are things like an ELK 9200. That has a 220 30 Amp relay in it and controlled by 120 volt module. Protocol of your choice. Though it is not a small case assembly size.
I use an Insteon device to control a 220v relay to.a hot water heater
I control power to the water heater via the Launcher or MobiLinc when remote to the location. I use Alexa voice commands when at the location.
