Ability to kickoff device load compare and reload from script
JPStokes
I've had my ISY-994ir for years (since 2013) and recently updated to version 5.  Everything has been going well except for one thing (which has happened for years as well).  After a month or so, some things stop working right.  I tracked it down to the load in a device not matching what the ISY thinks it should be.  So I do "Diagnostics->Show Device Links Table" and then hit Compare.  If there are any mismatches, I do the restore device. I have about 70 devices, so this takes a looooonnnnnnggggg time.  When I'm finished, everything is working again.
I asked about this a few years ago, but thought it worth asking again - Is there a way to get a capability to do something like the following in a program:
if Compare devicename then
then
     // do nothing
else
     Reload devicename
This would allow me to automate the entire process.  I could spread it over a month, doing a few devices overnight.  That way it would repair itself before it gets so bad that I have to manually do every device.
I'm not sure why the data gets corrupted - probably from power brownouts and blackouts - but it's happens enough that I wish for a solution.
Joe
