Insteon Thermostat #2441TH Max Temp Setting
To help manage heating costs, this program will allow for a slight increase in temperature and then changes the set-point back down. The 'heat' mode is needed to prevent the set-point from changing if the thermostat is in cooling mode or off.
MaxTemp TV Room - [ID 0004][Parent 0001]
        'TV Room T Stat - Main' Temperature >= 74.0°
    And 'TV Room T Stat - Main' Mode is Heat
        Set 'TV Room T Stat - Main' Heat Setpoint 72°
