Can't launch in any browser
My first day hasn't gone well at all. I installed the new 99i and the weather and network modules. Once I tried to launch it using the assigned address, it won't load in Firefox or IS. It's a blank screen in Firefox and a load error in IS. I get the following Java error:
Error: uncaught exception: [Exception... "Could not convert JavaScript argument arg 0 [nsIDOMWindowInternal.opener]" nsresult: "0x80570009 (NS_ERROR_XPC_BAD_CONVERT_JS)" location: "JS frame :: http://www.universal-devices.com/close.htm :: onload :: line 1" data: no]
It's not a good start and worries me that deployment of this product to customers may not be easy.
Do you have a Firewall?
I know Zone Alarm had to be told the ISY99is address before mine worked correctly.
I'm suspecting a router issue. however, I can access it through the 99i path, but not the other path. Could it be related to the basic screens that are not showing up on the web page. I get a blank screen and no errors other than the one above.
Strange
I came home from work and tried it again and it suddenly started working after a few failures.
Now I'm on to setting up smtp and some devices
