device settings in scene shown in admin console
What is the difference between the device settings (on level/ramp rate) when the highlight is on the scene name? and when the highlight is on an individual device as member of the scene?
I can set different settings for the devices depending on where the highlight is located. Isn't there just one set of settings for the scene?
I am having an issue in that the scene is being turned "on" (by a scheduled program) and the device settings don't appear to match those setup for the scene.
Each controller can have different on levels and ramp rates for each device in a scene. There can be multiple controllers within a scene. Highlighting the scene itself sets the levels for when the PLM itself is a controller (when the scene is controlled via ISY Programs for example).
Keep in mind that some INSTEON devices (such as SwitchLincs) may need to be power cycled before ramp rate and on level changes take effect. For a SwitchLinc, simply pull out the reset tab for about 10 seconds, then pop it back in.
