How to Open the ISY994i case - without breaking things
Is there a procedure for opening the front tab after the screws are removed?
I  am trying to replace the Zwave controller with the series 500 module and perplexed on how to open the case without breaking the cheap plastic.
Once the four bottom screws have been removed. If your unit has an external antenna remove it along with the retaining nut & washer.
Then remove the bottom plastic cover. From the rear where the ports are gently pull the (rear) case while lifting up the entire board.
Doing so will allow the entire PCB to come out. If you try to remove it from the LED (front of case) you’ll probably break something doing so.
9 hours ago, william.hullsiek said:
Okay stupid question - someone at the factory covered a screw with the label.
On my later purchased ISY994i. One of the case mounting screws is under the ISY994i  label with is Bar Coded part number.
The earlier one I have there was no label over one of the case mounting screws.
So it is very possible. You have a label covering one of the case mounting screws.
Edited by Brian H
