Help with Program to control pond heater involving both Scheduling and Weather data
FYI the heater keeps a hole in the ice to allow decomposition gases to exhaust.
So a few times a day I want to check the current temperature and run the heater for a variable amount of time.
IF (   Time is 5am or Time is 8pm )  -- Cheap hours
AND (OpenWeatherMap Temperature <= 0 and > -5.0)   -- Celsius
Set Pond Heater ON,
Wait 1 Hour,
Set Pond Heater OFF;
Unfortunately This program (and the 2 variants I have for running 2 and 3 hours) run more often than 5am and 8pm and often leaves the device ON;
What would really like is the equivalent of a CASE statement or the ability to derive and store the Wait time based on the Temperature.
CASE  Temp between -5 and 0 then Set waitTimeHours  = 1
CASE Temp Between -10 and -5.1 then Set waitTimeHours  = 2
CASE Temp < -10 THEN Set waitTimeHours  = 3
Q1: What are your suggestions for achieving variable Wait times base on Temperature readings?
Q2: Is there a way for the Program Name and Step to be added to the Log for viewing?  Is logging granularity adjustable?
Q3: Is there a way to prevent a program from running if another instance is already running?  Sounds like that is a no but asking just in case.
Many thanks in advance.
...Ray
Edited by rayg
I thought for sure I'd get several suggestions.  :-(
I started to reply but stopped because I figured someone else would have a better idea.....
But I would break it up into several programs
the First
If time is 5:00 AM
or time is 7:00 PM
or time is 12:00 AM
then
Run Temp_Range_1 (if)
Program Temp_Range_1
if temp <=0
and temp > -5
then
set pond heater on
wait 1 hour
set pond heater off
else
run Program Temp_Range_2
if temp <=-5
and temp > -10
then
set pond heater on
wait  hour
set pon2d heater off
else
run Program Temp_Range_3
etc........
All programs after the first should be disabled so they don't run on temp alone.
Edited by MrBill
Thanks I like the idea especially the smart use of the ELSE clause.
I am testing it now.
As for Disabling the others do I really have to do that?  They would never run on a temperature change event would they?
Thanks again for the reply.
...Ray
I believe that if you don't disable them they will run every time the temp moves.  Disabling them will cause them only to run when called by the time program.
