Saving a Value from a Node Server to a Variable
Just have to ask this question since I cannot find a way to save a value such as a Weather Value from a Weather node server to a variable in Version 5.  I believe I saw some posts back a few years that indicated that with Version 5 we would be able to do that.  At the time, the person was talking about the Climate Module and wanted to save accumulated rain to a variable for irrigation purposes.
Just curious if this ability is part of Version 5 and I just don't know how to do it or if that is something that is not included.  I have a work around so it is not critical, more curiosity than anything.
If this can be done, I would appreciate anyone pointing me in the right direction.
Thanks to all.
In a program:
Set the 1) Action to Variable, 2) pick a variable, 3) = is the default, that's fine.  4) Press the little circled play icon until you reach your Node Listing, 5) use the drop-downs to choose what to put into the variable..
Thank you Mr Bill.  Works perfectly and simplifies things. Much appreciate your help.
