Starting with version 0.11.0, NodeLink will use .NET 5. This release is a breaking change since it requires a new .NET runtime. If you're running on a Pi, just run the install script and everything will update as required. Another breaking change is the NodeDef files for thermostats (Ecobee, Honeywell and Venstar). There were previously separate node definitions for F and C. There is now a single definition which will dynamically changes units based on settings. This will break the exi
