off or on events when switch is off or on
I'd like to have ISY respond to, say, a "fast-off" action on a switch even if the switch was already off. Is there a way to do this? The reason for this, and I think this might be a common request, is that sometimes I bind fast-off to turn all lights off in the room. The switch that you are issuing the fast-off on may already be off for some reason. It is not user-friendly to have to first turn the switch on, and then fast-off, to get the fast-off action to trigger.
It should already work that way. Which version of the beta are you using because that was already fixed a couple versions back.
This is how you would do it with a program and the light can already be off and it will still work.
       Control 'Master Read Light' is switched Fast Off
       Set  Scene 'Inside All Scene' Off
I'm doing this in several rooms here, definitely works.
I love this feature. I use it all the time with my bathrooms. I double tap on or off to get both lights/fans in my master bath on or off in the AM.
If only I could get the ISY-26 to contorl my wholehouse audio. :)
