Harvvm Posted January 13, 2021 Share Posted January 13, 2021 I am experiencing an issue with the Wireless Tag Node server. Installed it a couple days ago and it appeared to work just fine. However today I needed to change a program and when I opened the Program tab it got as far as "create scene widgets" and then slowed to a stop. If to go into TaskManager to shut down the AC. The tree never loads. After hours of trying to troubleshoot it I discovered if I remove the WTNS the problem goes away. I have removed other NS and it appears the WTNS is the culprit. It seems to only affect the program tab. I can open all the other tabs with no problem. I am at 5.0.16C. Other NS running are Ring(PGC), MyQ, Ecobee, Kasa, OpenWeathrMap, TimeData, and HolidaysGoogle. Has anyone else seen this? If so were you able to fix it? TIA. Link to comment Share on other sites More sharing options...
Jimbo.Automates Posted January 13, 2021 Share Posted January 13, 2021 I've never had the AC stop like that, but could be a memory issue?https://wiki.universal-devices.com/index.php?title=Main_Page#Admin_Console_is_very_slow_or_hangs Link to comment Share on other sites More sharing options...
Harvvm Posted January 14, 2021 Author Share Posted January 14, 2021 2 hours ago, Jimbo said: I've never had the AC stop like that, but could be a memory issue?https://wiki.universal-devices.com/index.php?title=Main_Page#Admin_Console_is_very_slow_or_hangs Thanks Jimbo. That did the trick. Everything is much faster now. Link to comment Share on other sites More sharing options...
