neromir Posted February 14, 2021 Share Posted February 14, 2021 Hey, I picked up a Camect and found out about the node server for ISY. I haven't had a need for a polyglot server so far, so I've been setting that up over the last day or two on a Raspberry Pi I had sitting around waiting for a job. Anyway, I've got the polyglot server set up on there and running, but I'm having issues installing the Camect node-- it's spitting back an error at me about "polyglot cloneRepoError runinstallprocess undefined" in a banner at the top of the UI. From a little research here on the forums, I found how to attempt the manual install and have done so. The error from that is as follows Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple Collecting polyinterface>=2.1.0 (from -r requirements.txt (line 1)) Using cached https://files.pythonhosted.org/packages/e5/fd/36acbe1fa15805176523ff642632aaed896a40b876fdc4d039afdbd8c6a0/polyinterface-2.1.0.tar.gz Collecting camect-py (from -r requirements.txt (line 2)) Could not find a version that satisfies the requirement camect-py (from -r requirements.txt (line 2)) (from versions: ) No matching distribution found for camect-py (from -r requirements.txt (line 2)) So, since then I went to the camect-py docs on github (https://github.com/camect/camect-py) and ran the `pip3 install camect-py` mentioned there, but running the installation after that doesn't pick it up. Still getting the same problem. Any ideas on what to try next? A little further investigation reveals that we're invoking `#!/usr/bin/env python` in the shebang line; running `/usr/bin/env python --version` reports "Python 2.7.16" on my RPi, which won't work with the camect-py, I believe, since it wants to be installed via Python3's pip. Not sure how best to reconcile this. Link to comment Share on other sites More sharing options...
Jimbo.Automates Posted February 14, 2021 Share Posted February 14, 2021 The server.json specifies python3 so the shebang is not actually used. I'll try to figure out what is happening tomorrow.Sent from my Pixel 3 XL using Tapatalk Link to comment Share on other sites More sharing options...
Jimbo.Automates Posted February 15, 2021 Share Posted February 15, 2021 Just released 0.2.2 which should fix the issue, it will be in the store within the hour. Link to comment Share on other sites More sharing options...
neromir Posted February 15, 2021 Author Share Posted February 15, 2021 Looks like that got it. Thanks! Link to comment Share on other sites More sharing options...
