'Repeat 0 times' entries
This is fixed in Release 2.4.13
For Release 2.4.12 and earlier
Please do not use Repeat 0 times as this may hang your ISY.
       Repeat 0 times
Chris,
I still see the '0' as an option in the spinbox widget for repeat; is this correct?
Rand,
Please test this to see if it is now fixed in the new beta 2.4.13 release because I don't want to lock my box up. :P
Mark
Repeat 0 == Comment
Hum ok that makes since...sort of...not really.
Why not just make it named Comment or something that is easier to understand?
Maybe alias it in the java:
function Comment (args) {
    Repeat 0 (args)
Chris,
Rand,
Mark
Okay, I will, but a bit later :wink:
Repeat 0 could be used to comment out blocks of commands in a loop. That isn't what I intended when I did it though :shock:
Remember, I am the guy that discovered On Never, I now have a folder with that condition to build and test programs :o
I still desire some way to comment lines out of a program. There could be another button next to Remove Line, a toggle Comment Line. To test various lines when a program doesn't work as expected. :?
Rand
Mark,
Repeat 0 is supported because its just as easy to allow it as not. We currently do not support commenting out code in a program, that is why I mentioned using Repeat 0 to simulate it.
'Repeat X times' means run the following actions (up to the end or up to then next Repeat) X times. For 'Repeat 0' this means run them 0 times.
Okay, I tested it and Repeat 0 times is now a valid function!
So is Repeat Every 0 seconds.
Now I'm going to have too root around a bit harder to break something :D
Thank you,
Rand
