Bug: Scheduled times show True when past the time
These programs are showing "Idle: true" even though it is 11:19 am right now. Should they really be showing "Idle: false"?
       Time is Sunrise +  2 hours
       Set  Scene 'Inside All Scene' Off
       Wait  10 seconds
       Time is  2:59:00AM
       Set  Scene 'Inside Off LEDs' Off
       Set  Scene 'Inside On LEDs' On
       Time is  3:00:00AM
       Set  Scene 'My Lighting' Query
You can think of a 'Time is' entry as equivalent in behaviour to receiving an X10 message, or a Control event like 'Keypad A Fast On'. For 'Time is', the arrival of that specified time is the event, and as such the program will run.
The program True/False state is only changed when a 'relevant event' occurs, meaning that at least one of the conditions in your 'If' is testing for the event that occurred.
For Time Ranges (From/To, From/For), there are two time events, one when the 'From' time arrives, and one when the 'To' (or 'For') time arrives.
Therefore, in your examples, the program state will never become false (unless you add more conditions).
