ISY portal vs ISY local admin console
I have been previously using Mobilinc since I got my first ISY (and recently replaced that with a new ISY Zwave Pro)
i had used Mobilinc to relay the voice commands to Alexa by going into either the local scene or device and right clicking, selecting Notes, inputting the word or phrase into the Spoken field, then navigating to the Programs tab, Details sub-tab, then hitting Save Changes, which then pushed the info to Mobilinc and Amazon, which pushed the scene into my Alexa app.
I recently switched over from Mobilinc portal to ISY Portal and followed the instructions to enter the Echo commands into the ISY Portal, and that is all working fine, but...
Can you do the same thing via the regular local Administrative Console?  Where are the Spoken Phrases stored that were entered via the ISY Portal? Are these stored on UD's servers, or are these pushed locally to my Administrative Console?
I don't know why but UDI's portal does not use "spoken" field in the Admin console.   All spokens must be entered into your my.isy.io portal account.  It sure would be nice if it used the Spoken field.
Good to know @MrBill... I am assuming the portal account is stored on their servers and not pushed locally to my ISY... Can anyone verify if my assumption is true?
correct.  portal runs in the cloud on AWS instances leased by UDI.
