I need a Boolean ISY brain to help with some programming please....
I have been looking at this waaaaaaaaaaayyy too long and I should probably blow it up and start over.
I have tried so many options, but I cannot seem to get the logic correct.
Here is the scenario....
I have an automated dog door.
There are sensors on the dog’s collars that activate the door.
I have two sensors, one inside and one out.
The sensors are wired to a ZOOZ multirelay. ZEN16 (Z-Wave controller), that has 3 relays.
I have an KPL with three relevant buttons.
KPL.E= Lock-In
KPL.F=Lock-out
KPL.H=Both Locked
The concept is to be able control the dogs access locking them in the house or locking them out… They tend to run in front of cars but have been trained to run in the house when the driveway alarm goes off.
So, for example, when the alarm goes off, I want them “locked-in,” for 5-minutes but not “locked-out.”
In addition, I have several buttons throughout the house with “Both Locked” so I can see status or just provide two-way access the door.  Other keypads have all three options.
I had to create a program to turn the relay off, when the keypad button is on, to provide visual status of a locked condition.
I created three state variables lock-in, lock-out, both-locked.
The keypads all belong to scenes so that I can change the status of all the related buttons.
I have three programs, (total of 9) for each of the three conditions.
In Status Light
        $Dog_Door_Lock_In_Status is 1
        Set 'Dog Door / Dog Door Master Lock-In' On
        Set 'Dog Door / Dog Door Master Lock-In' Off
Lock In Control
        'Mudroom_Entry / DB.Dog Bath / DB.Dog Bath.E' Status is On
        Set 'Dog Door / ZW 015.1 On-Off Power Switch' Off
        Set 'Dog Door / ZW 015.1 On-Off Power Switch' On
Lock In Status
        'Dog Door / ZW 015.1 On-Off Power Switch' Status is Off
        $Dog_Door_Lock_In_Status  = 1
        $Dog_Door_Lock_In_Status  = 0
For the locked both I have:
Lock Both Status
         And $Dog_Door_Lock_Out_Status is 1
     Or 'Mudroom_Entry / DB.Dog Bath / DB.Dog Bath.H' Status is On
        $Dog_Door_Lock_Both_Status  = 1
        $Dog_Door_Lock_Both_Status  = 0
Both Status Light
        $Dog_Door_Lock_Both_Status is 1
        Set 'Dog Door / Door Dog Master Control' On
        Set 'Dog Door / Door Dog Master Control' Off
Lock Both Manual Control
        'Mudroom_Entry / DB.Dog Bath / DB.Dog Bath.H' Status is Off
        Set 'Dog Door / ZW 015.2 On-Off Power Switch' On
 I have tried it many different ways and happy to start over with a better solution.
If both lock-in and lock-out are on, and I hit the “both” button things enter a loop of turning on and off that required the programs to be stopped manually.
Ideas?
Rob
Without all the programs it's hard to trace, (you said you have 9 but I see 6).   The first thing to do tho, is not use status with your KPL buttons, instead use the "control" dropdown, and use OR in the same program for all equivalent keys on different keypads.
For example:
if
         'Mudroom_Entry / DB.Dog Bath / DB.Dog Bath.E'  is switched  On
      Or 'otherkeypad.E' is switched On
      Or 'anotherkeypad.E is switched On
then
that will probably clear up your race condition that occurs because Control means someone actually pushed the button, rather than the status that can also be triggered by scenes.   If you still have issues after that change, please repost with all programs included.
The easy way to post programs to the forum is to click on the program name, then right click and pick Copy to Clipboard, then in a forum post click the "<>"  in the toolbar which will bring up a popup window, then click in that window and type Ctrl-V.   Also if all the programs are conveniently grouped in a folder you can right click the folder and pick Copy Folder to Clipboard and post all with just one paste.
