AT&T to end email-to-text ×
Replaced a micro module because it stopped working. At first it worked fine then stopped working (local or remote). if I cycle power it works. The micro module started this way then quick completely. Why and is there a way to rest without cycling power?
Posted (edited)
You have a 2443-222 On Off, 2442-222 dimmer micro module?
It doesn't look like it has a Air Gap switch to cycle the power. It works for awhile and then stops responding completely? If their is lots of power line garbage it could be the modules electronics are getting scrambles and a power cycle cures it. Are you using the optional Sense Inputs?  That maybe causing issues.
The 2466S is a ToggleLinc On Off switch and has a Air Gap Switch to cycle the power. It is also a power line only module. So its Insteon Commands have to get to the micro module. By power line or a Dual Band Module sending the needed information.
Edited by Brian H
