ISY on Polisy 5.0.4 Not Found - Possible update issue
I had previously upgraded to version 5.04 and was able to connect to ISY on http://<ip address>:8080/desc via the finder. I have not used ISY on Polisy for a few days and several update packages were installed via the Polisy web page. Now the finder cannot find ISY on Polisy.
 - The Polisy service is running on Polisy. Tried rebooting Polisy.
 - If I try to update via ssh session, I get:
[admin@polisy ~]$ sudo pkg update
Updating FreeBSD-base repository catalogue...
pkg: https://pkg.isy.io/FreeBSD-base/FreeBSD:13:amd64/latest/packagesite.pkg: Not Found
FreeBSD-base repository is up to date.
Updating udi repository catalogue...
udi repository is up to date.
All repositories are up to date.
- If I check https://pkg.isy.io/FreeBSD-base/FreeBSD:13:amd64/latest/
There is no file "packagesite.pkg"  only  packagesite.txz
@gviliunas,
I had a similar issue and Michel had me run the following command:
sudo pkg upgrade -f FreeBSD-kernel-polisy  (don’t forget the -f)
I believe this forces an update of all FreeBSD files.  That made it possible for ISY Finder to see my ISY on Polisy and everything is running fine.
I still get the same "pkg not found" message, but Michel indicated that will eventually go away when that package is actually updated.
Hope this helps.
Mark
