Search ISY by Address/Scene #?
Can I somehow search my ISY database by INSTEON device address?  I would like to do this when I am looking at an unused INSTEON device and I don't know if I've added to the ISY or not.   Also, how about searching ISY by scene number which is Alexa gives you when you look at how something is defined in the Alexa app.
The closest easy method, is to view all, by clicking "ISY" (or whatever your root level is called) and then clicking the "address" column header in the right window to sort the table by address, then scroll down.
Another option is to run the Topology report.  Tools | Generate Topology.  The report will give you a list of all your devices along with their address and info on all your scenes. You're able to sort the columns in the report which can be quite helpful.
Edited by Techman
