If 'Light' is Greater Than 'Off'
I am trying to create a simple 'turn light' off if forgotten program. I have had this working on other lights, but this is one that is controlled from other locations also, and has a default 'on' state of 80%. So... I am trying to capture any scenario that has the light either being controlled locally or remotely.
This doesn't seem to work though. The program ends the same second that it starts.
       Status  'Room Light' is 80%
    Or Control 'Room Light' is switched On
    Or Control 'Room Light' is switched Brighten
    Or Control 'Room Light' is switched Fast On
    Or Status  'Room Light' is On
       Wait  1 hour
       Set 'Room Light' Off
I guess that I should have paid closer attention to the 'status' options.
I used '> Off' and it works very well. :oops:
I am curious why all the 'Or' commands caused this program to immediately end though.
Don't forget about the 'not' option, it handles all the code you have in one line.
       Status  'Room Light' is not Off
       Wait  1 hour
