PG3 Sonos nodeserver won't install
Bumbershoot
@bpwwer, I updated to PG3 3.0.35, and tried to install the new PG3 Sonos nodeserver.  The nodeserver doesn't install, with a red popup indicating something about "https is not supported" (I can't get a screenshot, as the popup doesn't persist for long).  Additionally, I haven't been able to retrieve the log from PG3, but I'll keep trying.  PG3 and ISY software are both the latest available versions running on Polisy.
EDIT: here is a snippet from the log
12/28/2021, 04:08:19 [pg3] error: MQTTS: ClientID: 00:0d:b9:53:3f:34_2 is already connected. Disallowing multiple connections.
12/28/2021, 04:08:19 [pg3] error: MQTTS: clientError: 00:0d:b9:53:3f:34_2 Auth Error
12/28/2021, 04:08:49 [pg3] error: MQTTS: connectionError: null connect did not arrive in time
12/28/2021, 04:09:13 [pg3] debug: ########## {"docs":"https://github.com/UniversalDevicesInc-PG3/udi-sonos-poly/blob/master/README.md","version":"3.0.0","status":"active","prem":true,"url":"  https://github.com/UniversalDevicesInc-PG3/udi-sonos-poly","name":"Sonos","language":"python3","nsdata":"","desc":"Add Sonos control/status to the ISY.","developer":"bpaauwe@bobsplace.com","ip_added":"67.161.168.17","purchaseOptions":[{"price":0,"isPerpetual":true}],"branch":"master","uuid":"00:0d:b9:53:3f:34","ts_added":"1640653506","ts_updated":"1640653506","author":"Bob Paauwe","price":0,"modified":"12/27/2021 17:5","profileNum":"6","nsid":"fceec281-4331-43c1-8c99-3ee17d2ceadb","expires":0}
12/28/2021, 04:09:13 [pg3] info: [00:0d:b9:53:3f:34_6] :: Creating Nodeserver 'Sonos'
12/28/2021, 04:09:13 [pg3] info: [00:0d:b9:53:3f:34_6] :: Cloning repository...   https://github.com/UniversalDevicesInc-PG3/udi-sonos-poly into /var/polyglot/pg3/ns/00:0d:b9:53:3f:34_6
12/28/2021, 04:09:13 [pg3] error: createNS: Error: Cloning into '/var/polyglot/pg3/ns/00:0d:b9:53:3f:34_6'...
fatal: protocol '  https' is not supported
    at Object.action (/var/polyglot/node_modules/simple-git/src/lib/plugins/error-detection.plugin.js:30:33)
    at PluginStore.exec (/var/polyglot/node_modules/simple-git/src/lib/plugins/plugin-store.js:21:33)
    at /var/polyglot/node_modules/simple-git/src/lib/runners/git-executor-chain.js:95:45
    at new Promise (<anonymous>)
    at GitExecutorChain.handleTaskData (/var/polyglot/node_modules/simple-git/src/lib/runners/git-executor-chain.js:93:16)
    at GitExecutorChain.<anonymous> (/var/polyglot/node_modules/simple-git/src/lib/runners/git-executor-chain.js:77:46)
    at Generator.next (<anonymous>)
    at fulfilled (/var/polyglot/node_modules/simple-git/src/lib/runners/git-executor-chain.js:5:58)
12/28/2021, 04:09:13 [pg3] debug: MQTT Results: [frontend/isy/admin] :: {"installNs":{"docs":"https://github.com/UniversalDevicesInc-PG3/udi-sonos-poly/blob/master/README.md","version":"3.0.0","status":"active","prem":true,"url":"  https://github.com/UniversalDevicesInc-PG3/udi-sonos-poly","name":"Sonos","language":"python3","nsdata":"","desc":"Add Sonos control/status to the ISY.","developer":"bpaauwe@bobsplace.com","ip_added":"67.161.168.17","purchaseOptions":[{"price":0,"isPerpetual":true}],"branch":"master","uuid":"00:0d:b9:53:3f:34","ts_added":"1640653506","ts_updated":"1640653506","author":"Bob Paauwe","price":0,"modified":"12/27/2021 17:5","profileNum":"6","nsid":"fceec281-4331-43c1-8c99-3ee17d2ceadb","expires":0,"success":false,"error":"Cloning into '/var/polyglot/pg3/ns/00:0d:b9:53:3f:34_6'...\nfatal: protocol '  https' is not supported\n"}}
12/28/2021, 04:09:24 [pg3] info: MQTTS: Client Disconnected: pg3frontend_qGw23
12/28/2021, 04:09:24 [pg3] debug: Client pg3frontend_qGw23 unsubscribed from udi/pg3/frontend/clients/beeaf904-1021-4a64-83ef-ea12b64492d9
12/28/2021, 04:09:24 [pg3] debug: Client pg3frontend_qGw23 unsubscribed from sconfig/#
12/28/2021, 04:09:24 [pg3] debug: Client pg3frontend_qGw23 unsubscribed from spolisy/#
12/28/2021, 04:09:48 [pg3] info: MQTTS: Client Connected: pg3frontend_DIqbN
Link to comment
Share on other sites
Refresh the store and it should work now.
Just for reference, the problem was that when I pasted the github URL into the form to submit it to the store, I had a couple of extra spaces in front of the URL. So '  https://...'  is not the same as 'https://...'
Link to comment
