Error Message CloneRepo: Non-zero exit code: 128
I have updated my ISY software to version 5.3.4 from 5.3.0 and Polisy Pro to version 5.2.0. Since then MyQ node has stopped working. I deleted it and uninstalled it. Then I tried to reinstall and received the message. cloneRepo: Non-zero exit code 128.
I have tried installing a few times and rebooting the ISY and Polisy with no success.
I could not find pertinent help on the forum.
Any suggestions?
Thank you
Is this an ISY994, or ISY on Polisy....
I suspect you mean ISY994 by the version numbers... but you posted in ISY on Polisy...
Thank you for your reply. Please give more specific instructions. I do not know what a terminal program is.
@Stagehand You might also check that you have a valid DNS server address set. Easy to remember and use DNS servers are 1.1.1.1 | 9.9.9.9 | 8.8.8.8. Login to your Polisy and then go to <Settings / Polisy Configuration> Scroll to the bottom and verify that you have valid DNS servers listed. If they are all 0.0.0.0 change them to what ever you are comfortable with or the suggested server addresses.
Edited by kzboray
I still have the issue but my DNS servers were indeed somehow changed to. 0.0.0.0. I made the correction but I still get the error code even after rebooting the Polisy and re-confirming I have the proper DNS servers. I think that was definitely part of the problem. Thank you for the suggestion.
I resolved the issue. Not only was my DNS servers incorrect as suggested by kzboray but I discovered that the IPv4 Gateway was incorrect. The error message has gone away and I successfully installed the node. Thanks for everyone's help.
