Custom Configuration Parameters missing
I just installed the PG3 version of the Flume node server. I had been running the PG2 version before. With the PG2 version there were fields required to get to my flume:  client_id, client_secret....etc. These are not available in the PG3 version. So no way to define my flume. I uninstalled it and reinstalled with no change.
Any ideas on what to do?
See screen cap from the PG3 config screen.
Steve1445859760_ScreenShot2022-01-10at9_34_50AM.thumb.png.350f9b2a08f923b348ccdefebcc77a68.png
So what happens when you hit the "Add Custom Parameter" button?
see below... I get a blank line for each time I click it. In the PG2 version, as I am sure you know,  it had the required params I needed to fill in.
Edited by stevehoyt
Yes that is the only version I installed according to the instructions in bpwwer's  post.
I think you are right about everyone jumping on PG3. As I am sure you have seen, there have been a number of comments about no more work being done on PG2 stuff. Hence the rush in my mind. Also the fact that the portal is open and the PG3 apps are for sale would tend to suggest things are up and ready to go for us users. My 2 cents. Maybe the powers that be should explain our options, timelines, and the risks.
As you may have seen in my previous post ( in the polyglot cloud server forum and questions and answers)  I have a couple questions about using the flume app that I hoped might be fixed by doing the upgrade. I am trying to create, using ISY and node servers, a way to detect excessive water usage in my sprinkler system.
Log file attached.
Thanks for your help
Steve
FlumeWater_1-10-2022_115224_AM.txt
Yes, I understand people jumping on PG3, just have to know with no official announcements of a supported release that you will likely have issues.  Personally I was going to wait and announce mine once I get all converted, 9 down 2 to go... Then worry about supporting everyone.
There is a issue with FlumeWater, I currently can't use it in production since it doesn't work with my new water meter, so its not as well tested as the others.
Thanks for the log, I'll try to get a fix out soon.
THANK YOU for the quick response. I will try and test it today, after the second cup of coffee kicks in. Though I have a birthday in the house to deal with today, so I may not get it done until tomorrow.
Being one who tries new things often, I have no problem running into glitches and with prerelease software. My goal is to get my project done, by the time I have to turn the sprinklers on next spring, so no pressure on you from me.
The only reason I bought the Polisy is for this project and for a migration path off my serial PLM when it dies.
 I have a completely separate 994 still running the house, so no issues if the polisy crashes etc.
I would be more than happy to be your alpha tester with the flume at my house, if it would be of value to you. I have muddled my way though ssh. Being a retired programmer/ network engineer ( think assembly language/ COBOL 50 years ago ) I can usually get things working. I am ok giving you remote access to my Polisy if that is possible/necessary. Let me know if there is anything I can do on that score.
PS
2 random thoughts.
1) I would charge more for your node server. Say $15. As I think you know, Flume has now gone to a subscription service for their advanced features.
2) When things settle down with you I would like to discuss making modifications to your flume node server that would make it easier for my project. You have made some comments on my earlier posts regarding this. Perhaps maybe repackage it as a new special purpose node server. I am OK funding your effort for some reasonable amount. The cost of water out here is a killer and I can easily lose $10 to $20 each day I have a broken sprinkler circuit.
Let me know your feelings on this.
Thanks again
Steve
Edited by stevehoyt
