Can MS-triggered program fall wayside if MS triggers in succession too quickly?
I have the program that's supposed to turn on exterior lights when a motion sensor is triggered.
But sometimes I'd find the lights stay on for hours long after there has been no motion outside.
     Status 'Exterior Sensor' is On
    Set 'Exterior Lights' Fast On
    Wait 5 minutes
    Set 'Exterior Lights' Off
   No Action
Looking at the log file, the only clue to the problem is that the motion sensor was triggered for a second time within the 5-minute period for the lights to be kept on.
Can that second motion trigger somehow have thrown off this program and made the lights stay on for the rest of the night?
You need to use "control" instead of "status" in the if statement.  With "Status" when the motion detector itself turns off the status is no longer "on" so the "Then" body is abandoned and "else" (which is empty) immediately runs.
The then body with "Control" will read "...is switched On"
After you've made that change, a second trigger of the motion will start the time over again, once there's no motion for 5 minutes the light will turn off.
Edited by MrBill
The conditional statement "If" operates differently than I expected.
In all the other programming languages that I've known, the entire "then" block is executed regardless of whether the "if" condition remains true throughout the execution.
I'll keep that in mind.
7 minutes ago, ISY Newbie said:
Correct, ISY program If statements are event based.  Anytime a value changes the IF is re-evaluated.
The reason "Control" works where "Status" doesn't is Status is reporting On/off/dim level/etc, whereas "control" is just looking for the action "switched on".
The other method that you might use when "control" isn't a choice is to link two programs:
Program 1:
       $state_variable = 1
then
       run program 'Program 2' (then)
Program 2:
if
      (none)
then
      disable Program 1
      turn something on
      wait 1 hour
      turn something off
      enable program 1
but if we do that we likely also need a program to make certain Program 2 wasn't running when the ISY restarted--- or in other words to get us to a known state:
Program 3:   [disabled][run at startup]
if
      $state_variable = 1
then
      Run program "Program 2" (then)
else
      turn something off
      enable Program 1
--- program 3 is always disabled but will run at startup if the run at startup flag is set.  Disabled means specifically that the IF won't be evaluated, the program does run if called by another program or called by run at startup.
